E type ( XK-E ) 1961 - 1975
Screw in distributor plugs
Old Jan 15, 2020 | 05:30 PM
Brian Dailey's Avatar
Default Screw in distributor plugs
How do you fab the wires to the distributor? I got this kit and cannot figure it out.
End of coil wire
thanks
Brian
Old Jan 15, 2020 | 06:24 PM
Jagfixer's Avatar
Looks like a graphite wire. I put the wire thru washer and curl up side of wire, then push in distributor and screw home.
Old Jan 16, 2020 | 05:49 AM
Coventry Foundation's Avatar
Brian that system is for copper core wire. Correctly done the wire is inserted in the copper disc and the wire ends splayed then soldered. When done correctly it is a very secure system where the solder blob actually mushrooms over the dist. cap tips.
Sidney Fabiani
XJ XJ12 ( X305 )
Jul 5, 2019 11:17 PM
Doug
Nov 6, 2016 03:45 PM
user 652867429824
Oct 16, 2015 12:32 AM
Vee
Jun 10, 2010 12:56 AM
loaks111
Aug 29, 2008 07:55 PM
