E type ( XK-E ) 1961 - 1975
Series 3 Ignition light
Old Apr 27, 2023 | 11:27 AM
JTsmks's Avatar
Default Series 3 Ignition light
While driving the other day I noticed I was on severe overcharge and my ignition light was on, upon a second start it was charging normal but the light was still on dim. I went ahead and changed the voltage regulator and now it’s sitting right at just over 13 as it should at idle yet the ignition light is still on dim. I don’t remember noticing this before or is this a normal occurrence or where should I check next on the ignition light?
Old Apr 28, 2023 | 09:33 AM
dibbyandco's Avatar
I've got a series 2, but the ignition light has flickered constantly since i got it about 9 years ago! Checked the alternator and it's fine, battery is fine and voltage just where it should be. So I ignore it until something changes! I think it's fairly common, there's a unit you can chsange I believe which may or may not fix it - your call.
Dan219
E type ( XK-E )
20
Mar 9, 2022 07:58 AM
JohnNH
Jan 22, 2022 10:04 PM
NathanDD6
May 8, 2016 02:11 PM
