E type ( XK-E ) 1961 - 1975
Sticky Clutch
Old Oct 9, 2011 | 10:31 AM
Neville's Avatar
Could be the clutch slave cylinder is returning too slowly or there is no free-play in the slave actuating rod. Try watching it from underneath while someone operates the clutch. When the clutch pedal is released the clutch fork should return pretty quickly.
Check the return spring on the slave is correctly attached and there is slight play in the slave actuating rod before the clutch pedal is pressed. The length of the rod is easily adjusted from underneath (as long as you don't mind grovelling around on the floor ....)
Old Dec 13, 2011 | 08:59 PM
oscaman's Avatar
Smile sticky
It could also be the rubber flex line comming apart internally and restricting the fluid transfering out of the slave cylinder back into the master cylinder and resivor as quickly as the pedal is released. There could be other restrictions such as the master cylinder rubbers or a pinched solid lne, but the old hose is the most likely. Of course we are assuming that all the linkages are nicely aligned and lubed. Good luck
ryan_border
Dec 23, 2015 04:27 PM
Johnken
Oct 1, 2015 05:07 PM
37driver
Oct 1, 2015 03:02 PM
dan102877
Sep 29, 2015 06:47 PM
