E type ( XK-E ) 1961 - 1975
V12 Rear Brake Noise
Old Feb 1, 2015 | 08:42 PM
trevv12's Avatar
Default V12 Rear Brake Noise
I have owned this V12 coupe for 30 years and for the recent time have suffered a “binding” noise from the rear brakes (when slowing at traffic lights for example). Under full braking there is no noise and effective braking. I have recently replaced or serviced the following components:
Brake Pads with copper grease at the piston face, Rotors, Calipers, Differential, Uni Joints, Radius- Arm Bushes. Does anyone have suggestions to eliminate the noise?
Old Feb 2, 2015 | 09:25 AM
Jagfixer's Avatar
Were calipers centered on rotors. How long was break-in period?
Old Feb 2, 2015 | 03:44 PM
Fraser Mitchell's Avatar
Are the rear brakes binding when off ? You can need about 200 miles to get the pads bedded in as the rear brakes don't do so much as the fronts.
Old Feb 5, 2015 | 06:41 AM
trevv12's Avatar
Hi Larry K
Thanks for your comments.
Yes the calipers were centred on the rotors.
I have installed several types of pads in the search for a solution and have given each the appropriate bedding-in procedure. The solution continues to evade me!!
Regards trevv12
Old Feb 5, 2015 | 06:51 AM
trevv12's Avatar
Hi Fraser Mitchell
My reference to "binding" was simply to describe the noise which emanates when braking lightly. No, there is no actual binding and the brakes do not drag at all. I shall continue to beaver away or learn to live with the noise!!
Regards trevv12
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
innzane
Sep 2, 2015 10:08 AM
