E type ( XK-E ) 1961 - 1975
why are 3.8 pistons marked "front"
Old Mar 14, 2015 | 08:09 AM
ajacobson's Avatar
Default why are 3.8 pistons marked "front"
I'm going to have some new pistons custom made and am wondering why the originals are marked front. Could it be because the pins are offset? They look symmetrical to me. Any ideas?
Old Mar 14, 2015 | 09:12 AM
Jagfixer's Avatar
Rod set and pin set require pistons to be replace as removed. Factory made it easy for fast undo and reassembly. Be sure rod and piston set is pulled that new pistons replaced same/direction way. Have shop mark pistons same way for next teardown. Makes it easier if something later on goes amiss. 2.4, 3.4, 3.8 and 4.2 are all marked.
Old Mar 14, 2015 | 02:16 PM
ajacobson's Avatar
Any idea why it makes a difference?
Old Mar 14, 2015 | 03:36 PM
plums's Avatar
Read up on "piston pin offset".
The piston pin bore is not on the centerline of of the piston.
Old Mar 16, 2015 | 12:02 PM
ajacobson's Avatar
Default Thanks
That's what I suspected. Thanks for the input
aode06
Jul 28, 2023 02:26 PM
LilaJagHubby
US Lower Atlantic
Mar 1, 2017 10:20 AM
SCMike
Nov 25, 2015 07:55 AM
BSM
Sep 25, 2015 05:00 PM
