E type ( XK-E ) 1961 - 1975
XKE 1969 series 2 ots
Old Mar 16, 2020 | 07:17 PM
Terry S Martin's Avatar
Default XKE 1969 series 2 ots
I have a question on the voltage regulator for the instruments.
If my reading of the circuit diagram is correct then the oil gauge and the battery indicator runs of 12 volts, with the water temp gauge and the fuel gauge run on the lower voltage.
If I am right is there a reason for running the wires thru the regulator
Old Mar 17, 2020 | 01:21 PM
billb44's Avatar
You are right but do not add these 2 gauges to the voltage regulator output. The volt meter will read 10.7v and the oil pressure will, I think, not be accurate. In any case, they will overload the regulator.
Old Mar 17, 2020 | 01:26 PM
Thank you
I am new to the E type, many quick fixes have been done over the years, I’m just slowly gong thru them.
this all started with a coolant overheat, I was hoping it was just indication.
slowcreek54
Sep 19, 2017 11:33 PM
adenshillito
Feb 21, 2017 09:35 AM
Jandreu
Apr 19, 2016 11:48 AM
CraigNelson
E type ( XK-E )
Jul 31, 2015 12:22 AM
ahunt4
Feb 16, 2015 08:16 PM
