Exterior Talk about your rims, bodykits, and other exterior mods here.
No front fogs
Old Mar 29, 2012 | 10:32 PM
Bad Cattitude's Avatar
Default No front fogs
My 2005 S-Type R did not come equipped with front fog lamps. Can I add these? What parts will it require and what sources have them?
Thanks!
Old Apr 5, 2012 | 10:20 AM
Panthro's Avatar
The 08 S-Type had an OEM foglight kit available from the dealer. Problem with that is they end up blocking the oil coolers behind the the fog-grills. You might be able to make it work if you switch the duals over to the 03-04 single cooler assembly, but that might be a bad idea. Jaguar changed over to duals for a reason. If you try this out though, make sure you post up & let everybody know how it goes. Hope that helps. And check Nally Jaguar for parts if you get them. Think we get a 15% discount & free shipping as forum members, since they're sponsers.
Old Apr 7, 2012 | 11:26 PM
Thanks!
Old Apr 12, 2012 | 04:24 PM
Panthro's Avatar
Exclamation
Hey Cat Man Do! Check this out.
redrover41
23
Sep 25, 2015 01:33 PM
1964Daimler
Sep 9, 2015 11:28 AM
motorhead69
Sep 9, 2015 10:04 AM
avern1
Sep 6, 2015 04:22 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
