F-Pace (X761) / C-X17 2016 - Onwards
Ethanol premium gas
Old Feb 20, 2025 | 07:38 PM
juan castrillon's Avatar
Default Ethanol premium gas
My f pace is working perfectly, but I used Costco’s gas and the check engine light came on, I don’t know if anyone has had this problem before, the mechanic said that it could be because of the ethanol in the fuel
Old Feb 20, 2025 | 11:01 PM
Rock Crawler's Avatar
What DTC’s are you getting?
Old Feb 21, 2025 | 03:15 AM
Robtrt8's Avatar
Put engine and trim in your signature or at least mention it in the post.
Old Feb 21, 2025 | 07:21 AM
it’s a cylinder misfire
jaguar f pace 2.5t premium
Old Feb 21, 2025 | 11:41 AM
Maybe a winter blend gas issue. Did your mechanic clear the codes and did they return?
Old Feb 21, 2025 | 12:57 PM
He’ll clear them this Sunday, he is gonna check it again.
Also, the panel shows that the hood is open even if it’s closed, I don’t know if that could be because the cold weather affected the switch
Old Feb 21, 2025 | 01:41 PM
Robtrt8's Avatar
That’s a common failure. Microswitch at the hood release fails causing alarm to go off. Especially in the seriously cold weather like what we have now.
If you don’t have a CEL then there isn’t a code set. At least not one to worry about yet. How many miles on car? Are you up to date on maintenance intervals?
Old Feb 21, 2025 | 10:21 PM
It has a lot of miles (170k), it warmed up a little today and all the lights went off, check engine light is gone and the hood open warning is gone too
Old Feb 21, 2025 | 11:30 PM
Good news!
Old Feb 22, 2025 | 03:49 AM
Robtrt8's Avatar
I wouldn't be so quick to condemn ethanol, especially from Costco. It's true, ethanol is not good but if it's only 10% or less and the gas is Top Tier and the fuel is turned over frequently then there should not be a problem. All of these conditions are met by buying from Costco. Personally, I buy from Mobil, using the Exon/Mobil APP and paying with the Apple Card. Rewards for buying premium and 3% cash back for using Apple Card. I'd change the spark plugs and look for a fouled plug. I would not pull the plugs and reuse them. I would buy a code reader so you can check codes yourself.
jahummer
Apr 8, 2025 02:35 PM
presidential27
Jul 23, 2012 08:04 AM
MDJag
Nov 17, 2010 09:30 PM
billinohio
Nov 29, 2007 07:07 PM
