F-Pace (X761) / C-X17 2016 - Onwards
Fpace infotainment not updating
Old Oct 24, 2025 | 11:57 AM
Peterinio's Avatar
Default Fpace infotainment not updating
Hi. My 2017 S model infotainment hasn’t updated since 16/12/2022 v S22A_22.32.4-928505
A few years ago the dealer says needs new hardware but not willing to spend the money on it. So many other issues so becoming a money pit. Would anyone know of a solution besides replacing the whole system? Likely not but just in case.
Appreciated. Peter
Old Oct 24, 2025 | 10:40 PM
dennis black's Avatar
Old Oct 29, 2025 | 09:59 AM
RoverJoe's Avatar
Community Influencer
22A is the last software release for the old IMC system, after the switch to PIVI in the facelift, there are no more SOTA updates. Either replace the IMC if you're having hardware issues, or look at a complete aftermarket overhaul solution, but be prepared to sacrifice some functionality, there's lots of things running through the OEM systems.
Old Oct 29, 2025 | 01:22 PM
Peterinio's Avatar
I am guessing my current IMC has issues so I would need to replace it with a new OEM IMC to solve the problem? If so that is a very expensive route. Would anyone know the part number?
Old Oct 29, 2025 | 01:58 PM
RoverJoe's Avatar
It has to be dealer programmed, and would need maps installed and SOTA reset via topix. It's not something you can do yourself sadly. Do you have a good independent shop near you that does JLR work? This is normally going to have to be done by a retailer, does your car fall within the warranty extension timeline? If you supply your VIN I can try to see what information I can get for you.
razorboy
Apr 24, 2026 10:42 AM
Peterinio
16
Nov 12, 2024 08:28 AM
johnevison
Jul 27, 2017 07:51 AM
Austin7
Mar 27, 2017 08:31 AM
Holeecow
Jan 6, 2017 12:42 PM
