F-Pace (X761) / C-X17 2016 - Onwards
Leaking Vent Hose Replacement 3.0L V6
Old Feb 21, 2023 | 09:50 AM
Simonusa0's Avatar
Default Leaking Vent Hose Replacement 3.0L V6
The attached link to a 3m 24s video
shows start to finish of the replacement of a leaking Coolant Vent Hose on my 2017 35t F-Pace. If you notice a slow coolant leak check this part first.
Background: I had noticed coolant loss from Max to Min mark on the reservoir over 8,000 miles. Fearing the worst that it was failure of the lower outlet ('Y') pipe's flanged joints (plenty of threads on this), I had it pressure tested at the dealership. The test passed but they noticed a small weep from the vent hose that connects the reservoir to the radiator header tank at the tank quick connect. Photos attached. Since this was easily accessible I did the replacement myself.
My time: < 4 minutes including hood opening and removal of the engine cover.
My cost: $52.81 partnumber T4A1783, $22 1 gallon coolant (that wasn't needed).
Dealership quote: $395.36 including 1h.6hrs labor of $321.30 @$199.99/hr
Preemptive comment: I am aware that dealerships have a minimum labor time charge (e.g. 1 hr) to cover check-in and paperwork etc.
Circled leak connection
Evidence of leak at joint
Old Mar 30, 2023 | 05:42 PM
VegasFPace's Avatar
well done!
Old Jan 18, 2025 | 03:26 PM
JIMDEE58's Avatar
I have precisely the same issue. How do you remove that unique looking connector?
Old Jan 18, 2025 | 03:44 PM
JIMDEE58's Avatar
Didn't realize you had put up a quite excellent video! Cheers!
Old Mar 17, 2025 | 09:37 PM
dmchao's Avatar
Did this resolve your leaking concern? I’m curious about this as I have a small leak but went from max to min in about 400 miles.
Old Mar 24, 2025 | 08:52 AM
Simonusa0's Avatar
Smile Leak was fully resolved
Yes, fully resolved.
Note there are numerous coolant system potential leak sources and causes so it's crucial to first diagnose the source properly. Usually by evidence of crusty coolant residue or by pressurizing the system and actually seeing the leak. In some cases, e.g. the 'y' pipe on the V6/V8 you may need a horoscope type inspection camera to see down in the Vee of the engine.
Old Mar 31, 2025 | 02:24 PM
dmchao's Avatar
Thanks, cheers! They pressure tested mine as I asked them to and there is no visible leak. I ordered this part to be safe and will replace it soon. Thanks for the description of your symptoms and resolution!
Old Apr 3, 2025 | 12:13 AM
Ichi Ban's Avatar
On the F-Type forum it's been suggested to shine a UV light source while wearing amber lens glasses to identify sources of leaks. Apparently, the coolant is phosphorescent under UV light.
Old Apr 7, 2025 | 02:58 PM
dmchao's Avatar
You can see it without amber glasses as well, its pretty bright. The vent hose did the trick for me, no more coolant smell after driving short distances.
Mine gushed coolant and I am pretty sure I had a bubble left in the upper rad. I topped off and bled the system, and my level is stable after a week.
RacingGreen87
Jul 28, 2022 09:21 PM
Fernando
Dec 21, 2016 09:02 AM
Dennis Catone
Nov 20, 2015 05:11 PM
Rickcusaf
May 2, 2011 08:32 AM
SJagR
Nov 22, 2007 09:20 AM
