F-Pace (X761) / C-X17 2016 - Onwards
Live oil level reading
Old Apr 6, 2026 | 06:55 PM
BritCars's Avatar
Default Live oil level reading
Does anyone know how to get the 'live' oil reading on a 2025 F Pace? My car is showing as 'overfilled' and I have extracted a half litre of oil but it still says overfilled. Not sure if that's because it is averaging over some number of recent readings, or hasn't reset to the new level yet. I ran the car, let it cool and it still says overfilled. But - perhaps that's a 'recent average'. How do I get the live reading? I tried hood open / drivers door open like on other Jags - doesn't seem to work. Any other suggestions. Earlier pre-facelift seems to display it on the instrument cluster. Mine is on the PiviPro
Welcome any advice
Old Apr 6, 2026 | 11:49 PM
RoverJoe's Avatar
Community Influencer
In general it has to run for at least 15 min and then sit off for at least 10 min to display the level. I will look to see if there's an engineering workaround, when I needed to I would use datalogger via Topix to display the actual measured value, so I know it knows it, but that moves fast and we don't want that display changing rapidly in the car.
Old Apr 7, 2026 | 12:23 AM
BritCars's Avatar
Thanks. In my F Tyoe (and I think in the pre facelift F Pace) if I open the hood and drivers door then double click the cruise cancel button it shows a live reading (ignition on, engine off). Means you don't need to wait the 10 mins and it updates to an actual rather than some sort of recent average
Maybe not possible on f pace. But - my worry is having pulled out 750ml of oil and still says overfilled it either was very overfilled or the electronic reader is malfunctioning
Do you know - if I drive it, shut off and wait the 10 mins. Is that readying what it seems in that moment, or is that averaged over some number of recent cycles?
Old Apr 7, 2026 | 12:30 AM
RoverJoe's Avatar
It should be a new measurement at that point, once it meets the measurement criteria, but I can't say that for certain.
Craaaazzy
Sep 8, 2025 11:50 AM
santacruz11
Nov 15, 2021 07:49 PM
carzaddict
Oct 14, 2021 11:07 AM
Holy F type
Aug 12, 2019 06:05 PM
Wguza
Mar 2, 2019 06:08 PM
