Real switch under the blank switch on steering wheel
Dont ask how but i removed the blank switch (easy step) on the steering wheel which is ideally meant for heated wheel.
now inside the switch there is a normal functioning button which you can press and a led like other switches.
My question is , is there a way to activate this button?
Maybe..maybe..jaguar installed heated wheel and just disabled it via blank switch.
Maybe some setting in fuse. I know most probably it might be nothing but no harm in trying.
You can see the button which can be pressed but it doesnt do anything, the led lits up.
hm yeah i can see how jag would make a generic switch panel - cheaper in the long run, not sure if the heating element would be in the steering wheel also, it might be costly enough to have production controls in place. I would imagine the wiring loom would be there, that would be cheaper to incorporate rather than have x amount of variants for all the options, but they certainly would have controls so they can charge to activate - the switch being one, probably a missing fuse and more than likely a software switch. Is there anything like 7 zap for jag where you could dig down into the part numbers see if there is a difference in the wheel?
Barrie Langlois
Feb 6, 2020 11:57 PM
