F-Pace (X761) / C-X17 2016 - Onwards
SVR cooled front seats ramps up and down.
Old Yesterday | 01:28 PM
ToxicFire's Avatar
Default SVR cooled front seats ramps up and down. and leather seat question
So another question for you fine people.
2020 fpace svr with the heated and cooled front seats.
on low and medium fan setting you dont really feel much air if any coming out the back or bottom HOWEVER the main reason im making this thread is because if i put it on max 3 the fan sounds like a jet plane but it will go super loud and fast then bog down to like it on setting 1 then ramps back up to full speed for like 3 seconds then drops back down and it does this constantly when i turn it to 3.
So a couple questions is this normal when on setting 3?
Is there a way to check if the ducts or connections are proper and not disconnected?
Whats the filter number for a filter change if our seats have them?
Front passenger leather seat i noticed an issue. Where the hole on the back of seat is the leather is loose on the bottom and theres a slight gap. Is there a way to fix this. Ill get a better picture of the exact problem this evening.
Old Yesterday | 02:04 PM
RoverJoe's Avatar
Community Influencer
No on setting 3 they should stay on full blast all the time, cycling sounds like there's an issue in the control side of that system. Is it the same on the backrest and cushion? They should be separate fans. That might narrow it down to a seat side issue or an HVAC module issue.
Old Yesterday | 02:22 PM
ToxicFire's Avatar
I didnt notice if just backrest or seat i thought it was 1 fan. Both driver and passenger seat does the ramp up and down though.
Old Yesterday | 06:16 PM
RoverJoe's Avatar
Looks like there may be software for this. If you provide your VIN I can check topix to see if your HVAC is at the latest level, to rule this out.
And just for reference, here's how the system looks inside the seats:
Old Today | 09:22 AM
ToxicFire's Avatar
Wow thanks for this. Sure ill pm you!
Old Today | 01:06 PM
RoverJoe's Avatar
Looks like you do have newer HVAC software available, and your car also has an open recall for PCM software updates.
NJ575SVR
May 10, 2024 10:09 AM
Purplecat18
Sep 25, 2023 08:58 PM
bigbadorange
Apr 27, 2022 11:40 AM
parnelli
Feb 16, 2021 05:56 AM
f_in_seattle
Feb 29, 2016 05:23 PM
