0.50 mm pistons
Old Mar 15, 2023 | 03:47 PM
autotech54's Avatar
Default 0.50 mm pistons
hello all I have a problem in 1 cylinder of v8 SC its just one deep line
I can't find anyone to do a sleeve for the cylinder in my area but found for boring the cylinder to 0.50mm less
so my question is did anyone did this before? knowing that the pistons +0.50 are not originals but we can find after market
thank you all
Old Mar 15, 2023 | 03:58 PM
CJSJAG's Avatar
Instead you might consider repairing the scratched cylinder.
Presumably if you bore one cylinder you should really rebore and fit oversize pistons all round.
Here is one article about repairing, and I am sur you could find others:
https://rennlist.com/forums/928-foru...der-walls.html
OTOH, why do you need to repair it? Is it really causing a problem or could you just drive it??
Old Mar 15, 2023 | 04:10 PM
autotech54's Avatar
yes I already opened the engine and found that scratch. Porsche did repaired before a v8 Panamera turbo but it had a closed deck and did sleeving
but this aj133 engine no body want to sleeve it for me and there is no genuine parts
the only solution is to to bore all 8 cylinders to 0.50MM and change all 8 pistons
the problem here is the pistons are aftermarket and by cutting the cylinder walls it will be weak??
I wanted to know if anyone did this before me with aftermarket parts
thank you
Old Mar 15, 2023 | 04:14 PM
autotech54's Avatar
and forgot to mention that the original sleeves in the aj133 is not nikasil its iron
Old Mar 15, 2023 | 04:17 PM
CJSJAG's Avatar
Have you considered replacing the block entirely?:
For example:
https://www.ebay.com/itm/26616095620...Bk9SR4ydg_LcYQ
Old Mar 15, 2023 | 04:20 PM
autotech54's Avatar
i am from France and buying from usa is not an option
Moppie64
Aug 9, 2022 10:25 AM
Jay111
Feb 16, 2022 04:34 AM
Reverend Sam
Jun 25, 2021 01:53 AM
Brandon Wright
Sep 1, 2016 04:38 AM
Toyroom
Jan 21, 2013 03:16 PM
