1st Oil Change on P300
Old Nov 10, 2020 | 10:44 PM
4pot's Avatar
Default 1st Oil Change on P300
Hello All, today I performed the first oil change on my '20 P300. The car has 2,098 miles and is just out of the break-in window. There is 0 chance I'm waiting to hit 12,000 on the factory fill. That's a terrible idea on a DI F/I 4-cylinder.
Per recommendation from a different thread, I purchased a Mityvac and this was my first time using it.
Aside from the oil fill capacity (6.9 quarts), the other difference vs. the 6 and 8 is the size of the oil filter housing. The 4-popper requires a 65/67mm x 14 flute oil filter wrench to remove. I believe the V8 uses a 90mm x 15 flute? The filter cap takes 25nm to tighten.
All went smoothly, and the Mityvac was great. The surprise was how much metal was in the filter! I'm glad I took it apart to look. I suppose this may be normal with so few miles on the ODO but WOW! I've never seen anything like this with any car I've owned. Does anyone have any feedback?
Old Nov 11, 2020 | 12:40 AM
takeapieandrun's Avatar
Wow that's a lot of metal. It makes sense for it to be higher than normal due to the initial break-in of tolerances in the engine, but that's surprising. I wouldn't worry though.
Old Nov 11, 2020 | 02:01 AM
Tel's Avatar
Tel
Never seen that much metal in a filter before, but I guess these days with Uber-tight tolerances that may be the norm?
Never ever saw metal after running in old engines with barn-door tolerances, the odd con rod yes, but that's a different story!
Old Nov 11, 2020 | 05:31 AM
scm's Avatar
scm
I've never seen so much space in the engine bay!
Old Nov 11, 2020 | 07:06 AM
SinF's Avatar
Good job on prudently doing an early oil change. You might have just saved your engine.
Filter pictures show unexpected amount of metal, you might have an internal problem or someone did a very bad keeping engine assembly line clean. I strongly recommend you do an oil analysis (I use Blackstone labs) and do the next oil change soon.
Old Nov 11, 2020 | 09:06 AM
Robc2562's Avatar
I just did my first oil change on my P300 last week also (at about 3600 miles) I also noticed those little specks of metal in the filter.
I don't get why Jaguar recommends such a long time to do the first oil change, the dealer near me recommended doing the first one earlier and not listening to what Jaguar said so I just went with that.
Old Nov 11, 2020 | 09:18 AM
Dwight Frye's Avatar
I understand that Jaquar offers free oil & filter changes within the warranty period. If you request an early change, does anyone know what the dealer may charge to do that ?
If exorbitant I would weigh the costs of buying a Mityvac, the required oil and filter and doing it myself.
4pot, which model Mityvac did you buy ? I'm lookiong at them online and see models 7201, 7300 and 7400, all with different options.
Regarding the metal particles in the filter I'd like to think that they were artifacts from the engine assembly and were caught almost immediately or during the first few miles of operation and remained suspended in the filter. But then again, who knows ? Good idea to change the oil & filter early, I have always done that with every new vehicle I have purchased. The negligible or modest cost to do that vs. the peace of mind is worth it to me.
Old Nov 11, 2020 | 09:25 AM
4pot's Avatar
4pot, which model Mityvac did you buy ? I'm lookiong at them online and see models 7201, 7300 and 7400, all with different options.Regarding the metal particles in the filter I'd like to think that they were artifacts from the engine assembly and were caught almost immediately or during the first few miles of operation and remained suspended in the filter. But then again, who knows ? Good idea to change the oil & filter early, I have always done that with every new vehicle I have purchased. The negligible or modest cost to do that vs. the peace of mind is worth it to me.
Mityvac 7201! This one is a hand pump that doesn't require shop air, etc. I purchased from a vendor on Amazon.
Great feedback, everyone. I still have the oil from the initial fill in the Mityvac and can send in a sample to start documenting wear materials. I also have another factory oil change kit on hand, so I can flush it out in 2-3k miles to see what's changing.
In terms of the flakes, I wonder if we're seeing turbo, bearings, or bore (or all 3)? I noticed the JLR spec oil isn't one of the newer Low Speed Pre-Ignition combating formulations (SN Plus)? And I'm really not sure what this specific Mobil1 ESP blend has for an additive packages. Does anyone have any feedback?
I recently watched the below video and it opened my eyes to the dangers of LSPI on modern direct injection motors. Coincidentally, I started researching LSPI after seeing a video of a 9A1 engine (2009+ DI 911 Carerra motor) with unusual rod bearing wear attributed to LSPI. I think it's something to be very aware of.
Old Nov 11, 2020 | 10:28 AM
Mahjik's Avatar
Keep in mind that "warranty" and "service" are two different plans. With most manufacturers, the service plan will cover a pre-set number of oil changes. However, those typically must be done on the manufacturers pre-defined intervals. i.e. if you want an oil change outside of their defined windows, you pay for it out of your pocket.
Old Nov 11, 2020 | 07:37 PM
Unhingd's Avatar
+1. This way you can verify whether it’s normal break-in or has something more sinister going on.
Old Nov 11, 2020 | 08:09 PM
4pot's Avatar
Indeed, I use Blackstone frequently and have the sample ready to ship out tomorrow. Assuming USPS doesn't lose or delay it, I hope to report back once the results are in.
If you want more data, another good one is SPEEDiagnostix:
https://www.speediagnostix.com/
Old Nov 12, 2020 | 08:21 AM
supersportmtl's Avatar
I'm definitely curious to see the results! Surprising amount of metal shavings.
Old Nov 25, 2020 | 03:35 PM
4pot's Avatar
Hello everyone, I received the oil analysis. Please let me know your thoughts! I will do a change again in 3-4k miles and send in for another report. If all is normal, I'll stretch the change interval to 6k.
Old Nov 25, 2020 | 07:49 PM
Carbuff2's Avatar
Don't I see them recommending another oil change and analysis at 2K - 4K miles?
as they mention, TBN is good. Other contaminants are OK, interesting that Moly is so low, I guess Jaguar doesn't use it as an assembly lube as Honda does.
Did you actually flush the engine/intake (BG, Seafoam, or CRC intake cleaner product) before the oil change?
Old Nov 25, 2020 | 08:39 PM
4pot's Avatar
Yes, I will do another change in 4k miles, or 6,098 total miles on the ODO. The car was at 2,098 miles at the time of this sample.
If the trends appear better, I will change at a longer interval thereafter. Actually, it would be perfect to hit 12,000 miles, and get the free Jaguar service.
I understand most will only change at 12,000 miles, which I think is crazy!, but maybe this is to benefit the next guy. My F-Type is a lease and I don't plan to keep it, but also don't want to be a bad steward. I've definitely been on the wrong side of extended oil change intervals and deferred maintenance from previous owners.
I flushed with Liqui Moly Pro-Line Engine Flush in the oil. Instructions were to pour into the (warm) oil, and let it run for 10 minutes at idle. No intake cleaning or anything like that, but I did put Ceratec in with the new oil, and will flush again at the end of this interval. I love Liqui Moly products. May be a bit of a waste of money, but I'll do it on these two initial oil changes.
Old Apr 25, 2025 | 06:04 PM
Ramart's Avatar
A caution for tool buyers preparing to copy this method: I was all set to begin, with a new Mityvac 7201, etc., but could not loosen the oil filter cover with the 65/67mm x 14-flute wrench I purchased. It kept slipping, possibly because the filter cover had been over-torqued last year by the Jag mechanic; but more likely because 65/67mm is too loose a spec (meant to also accommodate 67mm filter covers); or the brand of filter wrench I bought (PT/Performance Tool) had too shallow a socket to fit deeply enough over the cover's flutes, also leaving little room to insert the 3/8" driver. So I ordered a dedicated 65mm x 14-flute wrench (OEMTools brand) for overnight delivery from Amazon; its photo shows a properly deep-enough socket, and a 5-star review online commented that it fits Jags. If you're buying a filter cover wrench for a P300, I recommend getting 65mm x 14, not 65/67mm x 14.
RGPV6S
Oct 16, 2019 05:43 PM
neilr
Jan 28, 2019 11:29 AM
devo357
22
Mar 6, 2014 01:14 PM
Strafe
May 22, 2009 10:17 AM
marksj64
Nov 7, 2007 09:11 PM
