2014 Passenger Side Fuel Rail Removal
Can anyone point me in the right direction on how to get this fuel rail off? I've encountered two snags so far. One, the end of the rail that fits into the stainless fuel junction towards the front of the car doesn't appear to have any way to disconnect, even after I loosened the little nut that's on it. Two, I can't get the connector off of the other end of the fuel rail where the fuel pressure sensor is.
Any pointers or videos that may help me out here? Getting ready to burn the whole thing to the ground.
Here is a link that describes the procedure with photos:
https://www.jaguarforums.com/forum/f...p-step-220006/
To remove the high pressure fuel rail on the RH side of the AJ133/AJ126, you must loosen the three pipe unions and loosen the 8mm nut securing the junction block to the engine. It also helps to remove the Torx screws on the supercharger intercooler as well to allow the high pressure line to Bank2 to move.
The connector for the fuel pressure sensor has a small tab that must be lifted to allow the electrical connector to be removed. Be sure to cover the openings on the fuel rail once removed from the head.
Once you have the three or four bolts removed from the fuel rail mounts, it's helpful to use two shop towels wrapped around the fuel rail to put the fuel rail free of the injector o-rings. DO NOT pry the fuel rail out using leverage against the cam cover! Some or all the injectors may come out of their bores with the fuel rail.
The injectors that remain in the cylinder head require the special slide hammer to remove. You may encounter an injector that refuses to budge, but continue to use the slide hammer to eventually free it from the head. It may take patience and a few dozen hits of the slide hammer to remove it.
Once the injectors are removed, use brass wire brushes to clean and decarbonise the injector bores. DO NOT use any form of lubrication whilst fitting new injectors, or refitting the ones removed. If you're refitting injectors, remember to replace the o-ring and spacer as well as the Teflon seal. Use the special tool to resize the seal before inserting the injector into the bore. It's also best to use new injector retaining clips even when refitting used injectors.
Sorry about not being helpful. I didn't realize the fuel rails were different on the LH and RH sides until after NBs post and I looked it up in the repair manual.
It was still helpful, I appreciate the link. This has by far been the most frustrating maintenance I've ever done on this vehicle.
wordman
Jul 3, 2012 09:20 PM
