2014 v8s Supercharger belt change
Old 06-18-2020, 05:23 AM
2004XJ8's Avatar
Default 2014 v8s Supercharger belt change
Hi all,
My 2014 V8S is 6 years old and has just under 40k for miles. The maintenance schedules says to change the belt at 6 years or 60k whichever comes first?
Has any one done this and is it needed at these miles? If you have had it done what did it cost?
I am having my brake fluid and Diff fluid changed in early July and was wondering if I should just have the belt changed as well?
Thanks for the help and advice.
David Meier (06-18-2020)
Old 06-18-2020, 07:59 AM
Unhingd's Avatar
Received 4,652 Likes on 3,362 Posts
The belts should be good to 80-100k. Replacing at 60k is not excessively early. I have only replaced the front belt (supercharger) and can report that it’s a very simple job. With that belt removed, I can’t imagine that the accessory belt is any more difficult to replace.
Old 06-18-2020, 10:54 AM
JacksonvilleJag's Avatar
I was wondering the same thing as mine only has a little over 20k miles. Age wise I was worried, but I inspected the belt for cracks, tears, and dry rotting and it appears fine.
Old 06-18-2020, 11:45 AM
Rummy636's Avatar
Ive recommended as per 6yr/96K or if there's any cracking. I rather go with mileage than time unless issues seen. The acc belt is kind of a bitch. Need to take bracket off to remove belt.
The following 2 users liked this post by Rummy636:
Mbourne (06-18-2020), Unhingd (06-18-2020)
Old 06-18-2020, 05:25 PM
Mbourne's Avatar
I can say that with the V8 those belts are tough to see without taking apart the engine bay!
George05
11-15-2019 03:49 PM
Mike198
06-16-2017 12:51 PM
QuikCat
11-07-2013 05:17 PM
Colnago
07-31-2013 08:38 AM
Quick Reply: 2014 v8s Supercharger belt change
