2016 Base Dynamic settings
Old May 22, 2019 | 06:53 PM
maxiedaniels's Avatar
Default 2016 Base Dynamic settings
I know you can't configure dynamic mode in a 2016 base, but what are the defaults then for dynamic mode? As in, if I got an S instead, would I be able to make steering stiffer vs base or is base dynamic mode the most aggressive of all settings?
Old May 22, 2019 | 07:52 PM
OzXFR's Avatar
There are four things which can be changed using iDynamic if you have it (which you don't on a base) - throttle response, steering response/feel/stiffness, suspension stiffness and gearbox response. All four have only two settings - Normal and Dynamic. On a car with iDynamic the default setting for Dynamic mode is all four of those are set to Dynamic, and conversely if not in Dynamic mode all four revert to Normal ("soft"). But it is configurable, you can decide and set which of those four things change to Dynamic when you put the car in Dynamic mode and which stay as Normal. For example I drive in Dynamic mode all the time and I have configured the iDynamic so that three of the functions change to Dynamic but suspension stays in Normal, for a softer ride.
Old May 23, 2019 | 08:14 PM
Unhingd's Avatar
Oz,
I believe the question is whether the fixed settings on the base are closer to normal or to dynamic on the S. I can’t answer this question.
Old May 23, 2019 | 08:33 PM
OzXFR's Avatar
Originally Posted by Unhingd
Oz,
I think we have worked out over the years that the fixed setting on the Base are equal to the "Normal" (ie soft) setting in iDynamic for throttle response, gearbox and steering, but somewhere in between "soft" and "hard" (Normal and Dynamic) tending towards "hard" for the suspension/dampers.
Old May 23, 2019 | 08:44 PM
Mahjik's Avatar
I believe everything is in the normal/soft mode.
FWIW, I think the dampers behave better in Dynamic mode than normal mode. I also believe people without the Dynamic suspension are experiencing the lack of dampening with the standard suspension (and complain that it feels rough).
stmcknig
Jan 19, 2017 12:35 PM
jfranks
Dec 4, 2016 09:20 PM
supercat'dXKR
Jun 6, 2016 10:35 AM
bocatrip
Feb 22, 2016 10:04 AM
SCMike
Dec 29, 2015 06:19 PM
