2021 F Type R issues solved and Fuse 15
Old May 12, 2024 | 05:52 PM
  #61
Atipical's Avatar
Sorry I知 late to the party but I just got my FY21 car and I知 interested in pulling the fuse. The car is basically silent until 3500 RPM and I知 much more interested in having a lively experience. Isnt fuse 15 located in the fuse box on the driver痴 side of the engine bay under the hood/bonnet? (My car is a left hand drive car)
Old May 12, 2024 | 07:51 PM
  #62
Thunder Dump's Avatar
That is correct. It's a 5A fuse. When you take the splash panel off to access the fuse box (and put it back on) be careful not to drop the trim piece screws down in the gaps by the engine or you'll never see them again.
Old May 13, 2024 | 07:08 AM
  #63
Carbuff2's Avatar
Yeah, just raise the clip centers UP about 1/4" then pull the ENTIRE clip assembly up & out.
Old May 13, 2024 | 07:10 AM
  #64
CJSJAG's Avatar
I lost one and waited 4 months for JLR to get me a replacement before realizing I could purchase a set for $5 on Ebay.
They are used across the JLR range - just make sure you get the correct diameter.
Old Dec 29, 2024 | 06:29 PM
  #65
willfpetro's Avatar
Originally Posted by scm
I found the horn fuse in my then one year old R wasn't fully seated. They must a have weak person doing the fuses!
Regarding F15 - don't you get the same raucous behaviour in dynamic mode?
I am totally going to try this on my 2022 F Type R roadster. Thanks !
Old Dec 31, 2024 | 02:40 PM
  #66
luke2015's Avatar
Sorry to resurrect this post...or am I
I just did this with my 2021 F-Type R. It makes an enormous difference. Its akin to buying a completely new exhaust. I can tell you, it is absolutely not the same as turning on the active exhaust or putting it into dynamic mode. It'll pop from 1500rpm. It sounds just as good going 15mph as going 100mph now. I just wonder if it'll cause any possible issues. Not sure how it can, as the active exhaust is after the cats and mufflers so its really just open at the end now, I believe. God I love this car.
Old Dec 31, 2024 | 02:43 PM
  #67
luke2015's Avatar
Originally Posted by Ilyushin79
Im going to second this. I removed F15 in my 2022 P450 R-Dynamic and it's definitely louder, gets more crackles, pops, etc.
However, I think the simulated exhaust from the sound system is disabled with the removal of the fuse. The exhaust sounds less....deep. Still reasonably deep, but Cgo's charactarization of "raucous" is apt. There's a little less baritone (I suspect due to the Meridian system not injecting deep baritone sound anymore), but more overall volume and raspy growl with the pops and burbles when you're on your way down from 3500 rpm.
It does not contain fake sound. It has an active exhaust. I cant speak for the 23 onwards, but prior has no fake speaker engine noise.
Old Dec 31, 2024 | 02:53 PM
  #68
Well, in addition to the active exhaust, prior to '21 the cars had the symposer which injected exhaust noise into the cabin. That's not fake noise, but it is artificially amplified in the cabin. This can be readily defeated and has been done so by many members here.
From '21 and on (facelift cars), the symposer was replaced with the electronic NGPTSQ system, which *is* injecting fake exhaust noise into the cabin through the speakers and (to date) cannot be defeated. From Jaguar:
DID YOU KNOW ALL NEW JAGUAR VEHICLES ARE ENGINEERED TO SOUND AS GOOD AS THEY LOOK?
That’s because they are fitted with Next Generation Power Train Sound Quality (NGPTSQ) to electronically enhance existing sound and deliver a more rewarding driving experience.
By using data feeds for engine speed and gear selection, the system carefully constructs a non-intrusive digital audio enhancement, which is played through the audio system.
The sound will be imperceptible as an overlay and will be audible through the speakers even if the customer has the audio system turned off.
The result is a JLR vehicle with effortless power delivery enhanced by an engaging sound quality that builds to an acoustic reward consistent with the vehicle’s performance.
Tippo
Apr 1, 2022 05:45 PM
Jaesteban
Feb 10, 2020 09:00 AM
mrtalkradio
XJ40 ( XJ81 )
Feb 24, 2012 05:36 PM
frederikv12beauty
Aug 8, 2010 08:20 AM
jamesdunbar9
Jul 11, 2009 05:24 PM
