2021 ftype R tire sizes?!
Old Feb 19, 2022 | 02:09 PM
myironlung's Avatar
Default 2021 ftype R tire sizes?!
Does anyone know what the 2021 R 575hp tire sizes are ? I just had my original stock pzeros replaced and before the switch I had a ton of tire skip during cold weather and now with the new ones on I don’t get that, and the front ones also look smaller? The sizes I see currently are front: 265/30 R20 and rear : 305/30 ZR20
im trying to understand if they put the wrong tires on??
Old Feb 19, 2022 | 02:50 PM
scm's Avatar
scm
Sounds about right to me - I believe those were the sizes on the now discontinued SVR, also 575PS.
Edit: Oops, fronts should be 35 profile, I assume you made a typo?
Old Feb 19, 2022 | 02:55 PM
CJSJAG's Avatar
According to Tire Rack, your fronts should be 265/35 and rears 305/30, so the fronts do look a bit skinnier!!
If they replaced P-Zeros with new P-Zeros why would they change the size - unless they fitted what they get.
Why would you need to replace P-Zeros on a 2021, and why would you fit P-Zeros again??
Old Feb 19, 2022 | 03:13 PM
myironlung's Avatar
no it’s definitely 265/30. So they messed up?
Old Feb 19, 2022 | 03:14 PM
myironlung's Avatar
hit a pothole and they were all worn enough to replace. I’ve tried the Michelin’s and liked pzeros better honestly. Less tire skip
Old Feb 19, 2022 | 03:19 PM
scm's Avatar
scm
Yep! That'll be why they look smaller, then. The rear sidewalls will be 91.5mm and the fronts, at 35 profile, would be 92.75mm. At 30 profile the fronts would be 79.5mm, so would look much thinner than the rears.
Old Feb 19, 2022 | 03:43 PM
myironlung's Avatar
Thanks for the info! Is the smaller 30 safe to drive ? Any major difference besides visual ? I’ll call them when they’re open next week to switch them out
Old Feb 19, 2022 | 03:49 PM
scm's Avatar
scm
They'll be more prone to hitting rims on potholes since there's less sidewall to cushion it. Apart from that, should be okay.
Old Feb 19, 2022 | 03:59 PM
CJSJAG's Avatar
Even thought the installer screwed up, I would limit my driving to the return trip to dealer, if you expect to get full credit in replacement.
Old Feb 19, 2022 | 05:13 PM
myironlung's Avatar
yeah that’s a good point about less cushion. Plus I’ve noticed the tires are spinning and losing traction more easily with colder roads compared to the 35’s
Old Feb 19, 2022 | 11:30 PM
Thunder Dump's Avatar
Your speedometer and odometer will also be affected by the smaller size (albeit slightly). Smaller diameter means more revolutions for a given distance. So your odometer will actually record *more* mileage than you actually travel (by about 4%--tire will make ~768 rotations per mile vs ~738 rotations per mile for the correct size) and your speedometer will show you traveling *slower* than you actually are. So when your speedo shows 65mph you'll actually be going 62mph, and when your odometer says you've gone 100 miles, you've actually gone 104.
Old Feb 20, 2022 | 06:45 AM
DJS's Avatar
DJS
Also not good for AWD to have different front/back rotational speeds.
Old Feb 20, 2022 | 07:04 AM
Therock88's Avatar
Yes. This is the main concern. Different front and rear tire sizes will shred your transfer case/ drivetrain. Get them corrected asap.
DC
jcb-memphis
Mar 5, 2024 01:35 PM
alibaba
Jul 23, 2021 10:06 AM
aydeen
May 15, 2021 09:39 AM
thedude
Mar 24, 2017 06:17 PM
wotcham8
Jun 4, 2013 04:33 PM
