2023 Nissan Z car.
Old May 25, 2022 | 12:34 AM
  #41
OzXFR's Avatar
Originally Posted by bjg625
The price factor is big in this class. Supra, Z4 and a Nissan. If I was upgrading from an F86, Subaru, or a Miata I'd start and probably end with the Z. I've had plenty of fun cars not really fast, past Z cars and TT's. I had a really fast straight line SLK55 AMG and it was fun also, if bit expensive on rear tires. My favorite car of all time is my F Type,. 8.5 years now. Unfortunately now with a major mechanical problem, all signs point to a head gasket failure, won't know for sure till full disassembly by Friday. Shop is suspicious do to low mileage and no loss of oil or coolant, we'll see. I'm sure multi $1000's for sure.
I feel for you.
Your symptoms point to coolant in the combustion chambers = blown head gasket or cracked block, both not good.
But before the huge expense of disassembly I would ask for a simple and fairly cheap test first.
You can get test kits where you bubble some coolant (while the engine is running) through a container holding special blue fluid connected to the expansion tank, and if the coolant contains CO2 (ie combustion gasses) the fluid turns green/yellow.
Old May 26, 2022 | 12:11 AM
  #42
Cgo's Avatar
Cgo
Originally Posted by bfrank1972
Lol. What!? Whenever any manufacturer comes out with a long nose front engine auto design folks here instantly claim it is an F-Type ripoff. The design hails back to the original 240Z, which was a beautiful and unique design and still is today. If anything, I'd almost say the F-Type mimics more design cues from that car than the original E-Type. In the end doesn't matter, execution of the F-Type design (thank you Ian) is far better than any of the modern Z cars in my opinion. I just want to give mine a hug everything I see it.
100% My brother drove a 280z in college and it was a badass car. The 400Z is a retro design that looks a lot like the early Z cars with some other cues from the later gens like the 300 ZX.
Old May 26, 2022 | 12:16 AM
  #43
Cgo's Avatar
Cgo
Originally Posted by Burt Gummer
A couple friends brought up the feminine look of the new Z. Forced to agree. Some aftermarket parts might help butch it up a bit.
Feminine? No way. Definitely looks like a 270, 280 Z. This is how it should have evolved like the 911 did.
Old May 26, 2022 | 07:32 AM
  #44
19FRG's Avatar
hot gahhhhhbage.
Old May 26, 2022 | 09:24 AM
  #45
Mahjik's Avatar
Old May 30, 2022 | 03:45 AM
  #46
bjg625's Avatar
Thanks OXFER they are doing multiple levels of testing first, about $400 worth.
joycesjag
Feb 22, 2022 09:46 AM
santacruz11
Jul 1, 2021 06:52 PM
Dagger
Photography
Jun 13, 2016 11:55 AM
