5 point harness
Old Jun 25, 2016 | 12:09 AM
Bill W's Avatar
Default 5 point harness
Does any one make a hard bar and 5 point harness system for our cars?
Old Jun 25, 2016 | 06:23 AM
Unhingd's Avatar
I have seen nothing specific for the F-Type. You will need to custom fit and reinforce the attachment points. Unfortunately, a lot of trim work to cut through for the shoulder straps.
Old Jun 26, 2016 | 06:37 PM
lizzardo's Avatar
What about the fifth point? The only five point harnesses I've used come up through the seat base. That means replacing the seat with one set up for it, or cutting the existing and doing whatever upholstery modifications are necessary.
Perhaps I'm missing something.
Old Jun 26, 2016 | 10:55 PM
Unhingd's Avatar
No you aren't. That too if you want to do it right.
Old Jun 27, 2016 | 12:37 AM
lizzardo's Avatar
I was more wondering how one might do it wrong. Is there any way to get five points without seat modifications? Significant seat modifications?
Old Jun 27, 2016 | 01:22 AM
mp51998's Avatar
You shouldn't cut or modify a seat for the submarine hole. A seat without it is not designed for the forces encountered when the harness is "used" for safety. You would also need what is sometimes referred to as a tank plate to mount the harness to.it usually goes behind the seat at the rear mounting point and has connections for all five/six belts.
I am a little surprised a the lack of off the shelf racing gear for these cars. I have only been an owner for a month but looking for things like springs, wheels, sway bars for handling and then safety equipment like harnesses and bars or even roll bars/cages, especially since there seem to be so many convertibles,has been disappointing. Perhaps I am just looking in the wrong places. That stuff for my other car was plentiful.
Old Jun 27, 2016 | 09:02 AM
Unhingd's Avatar
If enough force is placed on that strap to deform the seat, a destroyed seat is the least of your worries.
These cars are too severely overweight to be considered viable track contenders. There just isn't enough market demand to warrant additional products on the aftermarket. With H&R and Velocity AP, we certainly have adequate spring options.
Old Jun 27, 2016 | 10:33 AM
lizzardo's Avatar
I'm not surprised. The car is more GT than Sports.
I'd really like to see a Superlight version. I think the Miata I picked up while my F-Type is being repaired is something like 1200 pounds lighter. I'm not saying that the F-Type should be 1/3 lighter than it is, because the Miata is tiny and pretty austere, but 15-20% weight reduction would really be exciting. There were some luxury options I couldn't exclude that I really didn't want. Weight, weight, weight.
Old Jun 27, 2016 | 02:01 PM
mp51998's Avatar
I guess I should have said you should not modify a seat to accept a harness if it is not designed with that in mind. I know we have the shoulder pass throughs but are they really functional?
Old Jun 27, 2016 | 08:12 PM
lizzardo's Avatar
Without a harness bar the point is moot.
Old Jun 28, 2016 | 03:54 PM
F-typical's Avatar
No, what you have are overstuffed wingback armchairs with hole in the backrest. It takes two mechanics to lift them off the workshop floor.
Just no...
Old Jun 28, 2016 | 06:44 PM
Bill W's Avatar
Thanks for the discussion. I can agree that the F-Type, as is, is too heavy to be really comptitive. However, if I want to do an HPDE just for fun, I still want to be strapped in pretty tight.
Old Jun 28, 2016 | 08:25 PM
sybarite's Avatar
Just get a CG Lock.
Old Jun 29, 2016 | 02:31 PM
mp51998's Avatar
Originally Posted by sybarite
Just get a CG Lock.
I was just going to say that. Use them in both my other cars and they work really well.
Old Jun 30, 2016 | 11:07 AM
lizzardo's Avatar
I tried a CG Lock a few years ago and it was OK until it the mechanism on the release lever failed.
hoodun
Jun 6, 2017 06:38 PM
harvest14
Jan 8, 2017 03:03 PM
dcarr
May 15, 2016 01:57 PM
Kief
Apr 26, 2016 10:29 AM
Col. Sandurz
Apr 19, 2016 12:57 AM
