6/8 Cylinder development story?
Old Feb 4, 2021 | 09:55 PM
RAWONE's Avatar
Default 6/8 Cylinder development story?
I'd like to learn the development history of our engines. I've heard it was a modified Ford, all JLR and even BMW. I don't think i've seen another manufacturer create a 6 from an 8 by basically just using shorter heads on an 8 block. Anyone know where I can read up on this?
And I guess while i'm at it, since the blocks appear to be the same, shouldn't a 6's manual tranny bolt up to the 8? Is the bell housing bolt pattern same as ZF? I gotta believe someone has looked into this already. Forget all the silly "won't handle the power" details.
Old Feb 5, 2021 | 04:44 AM
scm's Avatar
scm
All JLR (actually all J), built at Ford's Bridgend engine plant in a special "Jaguar area".
Old Feb 5, 2021 | 11:11 AM
NigelW's Avatar
A good place to start; there are some links the bottom of the page as well. The V6 is referenced on the page.
https://en.wikipedia.org/wiki/Jaguar_AJ-V8_engine
Old Feb 5, 2021 | 05:17 PM
Unhingd's Avatar
Even if you could bolt a ZF 6S–45 to a V8, you’d twist it into a knot in short order. It just couldn’t handle the torque.
Old Feb 5, 2021 | 05:27 PM
sov211's Avatar
This is correct; the engines were designed/engineered by Jaguar (not Ford) and built under contract in a separate facility at Bridgend. The engines were not shared with Ford products and the Ford 5.0 engine is not the same as the Jaguar engine; the V6 is essentially the Jaguar V8 with two cylinders fewer.
Old Feb 5, 2021 | 07:09 PM
OzXFR's Avatar
See here for a good explanation of how the V6 was derived from the V8: https://www.caranddriver.com/news/a1...ers-redundant/
Old Feb 6, 2021 | 05:02 AM
RAWONE's Avatar
I figured as much. Note my last sentence in original post. But....any aftermarket options? Just thinking out load here.
Unhingd
Jan 14, 2026 05:31 PM
kmarajh
Oct 23, 2016 10:12 AM
AristoCat
Sep 30, 2014 09:20 PM
lawnerd
General Tech Help
Jul 2, 2014 06:42 AM
ekatspm
Sep 25, 2011 09:09 PM
