800BHP Barrier Broken - VelocityAP Billet Camshaft Set Announcement
Old Jan 7, 2026 | 01:31 PM
scott@VelocityAP's Avatar
Sponsor
Default 800BHP Barrier Broken - VelocityAP Billet Camshaft Set Announcement
800BHP Barrier Broken!
We promised you big things in store for 2026, and we’re coming out of the gate hot. For some time now we’ve been testing & tuning some new products behind the scenes for the 5.0L Supercharged JLR platform engines. Our Harrop 2300 Kit releases for F-Pace SVR & F-Type have been well received and for those who demand even more, this is where the next chapter begins.
Our Billet Camshaft set has been designed to optimize camshaft lift and duration for increased flow and power levels, unlocking power levels the stock components simply cannot achieve. However, these cams do not produce significant power on their own; our proprietary complimentary ECU calibration changes are required to unlock the additional potential.
+60BHP Peak Power
+10BHP Peak Torque (+20-30ft/lbs through power band)
This a fundamental step forward for high-output JLR builds targeting the 800+ BHP threshold.
Limited quantities are in stock & ready for immediate shipment.
https://www.velocityap.com/product/h...eid=66509f0b99
__________________
Scott Rudowitz
Business Development Manager
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: scott@velocityap.com
www.velocityap.com
Old Jan 7, 2026 | 01:39 PM
Sponsor
YOUTUBE VIDEO:
__________________
Scott Rudowitz
O: (1)250-485-5126
www.velocityap.com
Old Jan 7, 2026 | 04:19 PM
71camaro's Avatar
Kind of sad on that last line, "cams aren't lumpy."
I wouldn't want to sound like a cammed-out big block Chevelle, but a little lope would be welcome lol.
Old Jan 8, 2026 | 06:45 AM
SassySarah's Avatar
I totally agree. A bit of cam lope is classic old school "bad ***".
Old Jan 8, 2026 | 12:28 PM
Stuart@VelocityAP's Avatar
You can make the cams lopey with a 'ghost cam' tune - have tried it but unless you're pretty much straight piped it's not as impressive as you'd expect and it starts to impact low speed driveability.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Jan 8, 2026 | 03:54 PM
RoverJoe's Avatar
Community Influencer
Doing it via VVT/timing?
I had someone tell me on my corvette that you could tune in the cam lope using just idle timing adjustments, as my old LS2 does not have VVT... I'm like no, making it surge is not a replacement for cam chop. With actual VVT you can simulate the change in LSA on an aftermarket cam that usually gives the classic choppy idle, it's pretty funny how it can be turned on and off in the new engines via tuning.
Old Jan 15, 2026 | 12:08 AM
71camaro's Avatar
So, @scott@VelocityAP , is this an engine-out job?
Old Jan 15, 2026 | 07:42 AM
Sponsor
No, it can be done while still in the vehicle, although not a quick/simple job. Would highly recommend professional installation.
__________________
Scott Rudowitz
O: (1)250-485-5126
www.velocityap.com
Old Jan 16, 2026 | 05:51 PM
Gasman2's Avatar
How many hours labour would this take tks
Old Jan 16, 2026 | 06:13 PM
Very much a 'your mileage may vary' question. Probably 15 hours or so for most techs, if they are much more familiar with the platform maybe less.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jan 16, 2026 | 06:31 PM
Gasman2's Avatar
Gulp
have to save a bit more to cover fitting cost
Old Jan 16, 2026 | 08:31 PM
RoverJoe's Avatar
Also lash setting on these engines is via shims, so any adjustments require parts replacements if you can't get lucky and swap the existing ones around to get in spec. It's a time consuming process, not particularly difficult, but lots of repetition.
scott@VelocityAP
F-Pace (X761) / C-X17
Mar 18, 2026 03:23 PM
Jag Bass
General Tech Help
Dec 17, 2023 04:18 AM
Vauxi
Feb 26, 2022 12:33 PM
sts-v
Jan 18, 2018 06:37 PM
retriever-007
Feb 7, 2015 08:24 PM
