83 miles new and this happened...
Old Dec 17, 2015 | 11:02 PM
Greggbhill's Avatar
Default 83 miles new and this happened...
Really hadn't expected to try out the roadside assistance so soon. I guess the good news is it was in my garage.
The car is apparently so new it wasn't in their system yet (it is now)
Old Dec 18, 2015 | 05:36 AM
uncheel's Avatar
Cat not housebroken yet.
Old Dec 18, 2015 | 08:28 AM
DJS's Avatar
DJS
Can't tell if it's just water from A/C condensation, or something else. Any word yet?
Old Dec 18, 2015 | 08:38 AM
jm717's Avatar
I think the coolant is orange, at least it is in my 2014. If the fluid is orange and feels a little oily or like soap then my guess is coolant leak.
Old Dec 18, 2015 | 09:09 AM
Greggbhill's Avatar
It is definitely orange- based on my experience with the XKR I would wager it is coolant. I was expecting a lot more this morning in the bucket I put under it, so maybe it is just an overflow situation (not sure if that makes sense)
Waiting for tow service to arrive...
Old Dec 18, 2015 | 09:48 AM
jm717's Avatar
If I were you I'd check the coolant level, just to see how much it lost. If there is no fluid in the reservoir then you lost quite a bit. If it is way over Max then I suppose it is possible that is was just an overflow. You want to check the coolant regularly for a few weeks after they fix it anyway. Some pics below in case you need a pointer.
Old Dec 18, 2015 | 09:49 AM
Foosh's Avatar
+1 What he said above.
Old Dec 18, 2015 | 10:34 AM
DJS's Avatar
DJS
I like that your coolant matches your paint. Is that special Firesand coolant?
Originally Posted by jm717
Old Dec 18, 2015 | 10:56 AM
jm717's Avatar
I assumed everyone got color matching coolant I get Firesand gas, windshield washer, brake fluid, motor oil and Irish coffee!
Old Dec 18, 2015 | 01:53 PM
deltagroup's Avatar
I also wonder about your coolant level. Doubt it's a cracked reservoir tank (you'd likely feel moisture on the tank's underside), though your pics certainly show a pretty (un)healthy leak. My bet is on a loose hose/hose fitting.
Old Dec 18, 2015 | 01:58 PM
Greggbhill's Avatar
Haven't heard diagnosis yet, but getting loaner process was super!
Old Dec 18, 2015 | 03:35 PM
BMo's Avatar
BMo
Keep us posted. I need to go get some orange coolant as the coolant cap clearly indicates not to be puttin' green stuff in there!
Old Dec 18, 2015 | 05:04 PM
StealthPilot's Avatar
Yep that's British engineering right there!
Old Dec 18, 2015 | 08:53 PM
Greggbhill's Avatar
so the nice service department lady said to get familiar with the loaner (XJ) - apparently the radiator failed and needs to be replaced. first they have seen. bummer - ETA is 5 days :-(
Old Dec 18, 2015 | 09:02 PM
Foosh's Avatar
Wow . . . that is a rare failure on a new car. However, parts are more likely to fail either when they are brand new or when they are old and worn out. It could also be as simple as a rock launched into it. The good news is a radiator replacement is rather simple and not something I'd ever worry about again.
Old Dec 19, 2015 | 01:14 AM
1 of 19's Avatar
Rub her nose in it and toss her outside for the evening. She'll get the message.
Old Dec 19, 2015 | 01:19 AM
Greggbhill's Avatar
You mean the car, not the nice service lady... Right?
Old Dec 19, 2015 | 10:43 AM
deltagroup's Avatar
Never would have suspected the radiator. At least, not at 83 miles....
Old Dec 22, 2015 | 06:51 AM
Foosh's Avatar
Something tells me it's not the radiator per se, and I haven't seen the resolution yet. The connections to the radiator are the most likely suspects.
Old Dec 22, 2015 | 08:27 AM
Greggbhill's Avatar
They had to order the radiator and it is supposed to arrive today. Hoping to get it back by tomorrow. Will post any details they give me.
