Active exhaust compressor removal
Old Dec 31, 2016 | 07:20 AM
Mueller's Avatar
Default Active exhaust compressor removal
Has anyone had the TSB done regarding the active exhaust compressor noise because it makes noise constantly at low speeds? I believe they remove the compressor and run the vacuum lines off the engine. Does the exhaust still work the same? Are there any adverse effects of having this TSB done? I am on the fence of whether it is worth it. The compressor runs all the time when I am in stop and go traffic and it's rather annoying and I feel like people can hear it when I'm on conference calls in the car. Any input would be appreciated.
Old Dec 31, 2016 | 10:14 AM
F-typical's Avatar
If it's running the whole time, either or all of the following could apply:
1. You have a vacuum leak;
2. The pressure sensor has failed;
3. It isn't actually pumping - even though it's running.
Old Dec 31, 2016 | 10:49 AM
f-driver's Avatar
Got the tsb done on my car two years ago. Active exhaust works like before.
One problem i see is that there now is a long vacuum tube on the floor of
the car which isnt covered very well. If there will ever be a leakage in the exhaust
vacuum system the engine will suck in a lot of dirty air which would never occur
using the electrical pump.
Imho keeping the original pump is the better solution .
Regards
Ulrich
