Alarm malfunction
Old Dec 25, 2025 | 10:14 PM
Jag Bass's Avatar
Default Alarm malfunction
Anyone run into the issue where the factory alarm starts going off right after you lock the doors?
Old Dec 26, 2025 | 04:33 AM
DMeister's Avatar
Not sure if anything here could inspire anything? ->
https://www.jaguarforums.com/forum/x...r-help-203838/
Here’s a guy with an F-type that at least seems to be having the same issue specifically with an F-type ->
https://www.facebook.com/groups/7402...2841201928151/
Old Dec 26, 2025 | 05:58 AM
scm's Avatar
scm
Any wildlife buzzing around inside setting off sensors?
Old Dec 26, 2025 | 06:06 AM
Jag Bass's Avatar
No, lol.
Old Dec 26, 2025 | 08:14 AM
RoverJoe's Avatar
Community Influencer
If you have diagnostic software you can look at the recent alarm triggers and see why. My guess is a door latch failing and not indicating locked, but without diag that's just a guess.
Old Dec 26, 2025 | 11:05 AM
Jag Bass's Avatar
May have something to do with the passenger door handle issue that is being addressed Monday by jaguar. Has a bad motor and being replaced under warranty because it is poping in and out randomly. The alarm issue just started though.
Old Dec 26, 2025 | 11:13 AM
scm's Avatar
scm
If a door lock is failing wouldn't that just stop the car from locking, not trigger the alarm?
Old Dec 26, 2025 | 10:12 PM
RoverJoe's Avatar
Usually what fails is one of the lock state switches. The BCM looks at the door being closed, then sends the locking signal. It then monitors for the locks being opened or doors being opened without a verified signal from a key. Just a suggestion, it could be any source tripping it, that's why you scan it. It's not going to be a door ajar switch, because you would get a mislock beep and the alarm would not set. But there are 3 microswitches in each door latch, only takes one to give you an issue.
Old Dec 26, 2025 | 10:15 PM
RoverJoe's Avatar
Didn't see this before answering the post under yours, this makes perfect sense then. The lock/unlock is reflected by the door handles. If the motor was bad it just wouldn't move, you have a switch issue where the car thinks it's not locked so it does what it's supposed to do and commands the handle back out. Going to be related for sure, one part should fix both of your issues.
Old Dec 31, 2025 | 05:45 PM
Jag Bass's Avatar
Car back from dealer and they replaced the actuator motor and said it was fixed. Pulled into garage got out and passenger door handle started poping in and out just like before. Locked the doors and alarm started sounding same as before. Going back next week, joy
Old Jan 2, 2026 | 09:11 AM
RoverJoe's Avatar
Yeah it's more likely the latch than the door handle motor. Not common on the F-type, but in general door latches are a weak point across the JLR lineup.
Old Jan 3, 2026 | 12:08 PM
JagCode3's Avatar
@Jag Bass It is worth pulling off the door card and taking a look at the wiring, connectors, and latching mechanism. Since you were the pioneer who reported the water intrusion issue onto the door speakers, you could also check if there's been any water intrusion to these areas of interest.
https://www.jaguarforums.com/forum/f...damage-267682/
Old Jan 3, 2026 | 03:02 PM
Jag Bass's Avatar
The dealer ordered an entire handle assembly to replace the right one. Another member on another thread provided a service writeup for his 23 F-type that was having the exact same issue, that was appaemtly the fix. Odd think is the tech said the computer had reported a short in the acuator motor. They replaced that and everything seemed to be working fine at the shop. Apparently a drive cycle needed to happen before the problem presented again for whatever reason.
Old Jan 3, 2026 | 05:46 PM
RoverJoe's Avatar
They almost never give faults for the latch switches failing, they just act up when locking/unlocking. The handle fault probably set when it was trying to cycle in and out quicker than it should.
manonbike
Mar 1, 2017 01:29 PM
burmaz
Nov 29, 2011 11:49 PM
abwoon
Sep 5, 2009 12:54 PM
