Aluminum Cooling Pipes - Finally!!
#501
The bit itself's 6 inches, the extension's another 7. IF you know of something 15 inches or longer, point me in that direction, it might help. Haven't found anything longer other than a long reach TORX screwdriver. But the problem still is the bit either hits the cylinder heads, the supercharger snout, get's stuck in the tight gaps, can't really get a long straight bit in at a 45 degree angle with everything in the way.
#502
Well, my mechanic uses Snap-On . You know, the one that mechanics blame when they charge you $150 an hour. So, if you try them just remember to take along a lot of money.
Harbor Freight might have longer ones or perhaps you know a mechanic that can loan you one.
On a side note and not meaning to get personal, do you take your engine apart and put it back together just for grins or do you just like punishment?
#503
As I've mentioned, I've worked on all of my vehicles for years and so it's quite easy for me to take things apart and put them back together and quickly. Especially helps to have the right tools as well as I've learned over the years.
#504
Here is a set that is 12" long? Screw driver handles so might not work? Cheap enough to try?
#505
#506
peppersam740 (05-12-2024)
#508
I would buy those cheap 12" long Torx screw drivers I posted above and then cut off the screw driver handle off and weld a cheap HF 1/4" adapter on it? Heck you could just grind the end of the steel rod square and put a vice-grip on it?
The set of 6 is only $22.
#510
PetanoCZ
XF (X260)
11-27-2023 03:03 PM
Pete Mantell
03-27-2016 10:28 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
