Anyone else have pump noise?
Old Jun 16, 2017 | 08:07 AM
JackMac's Avatar
Default Anyone else have fuel pump noise?
Went in for first annual maintenance this week. Mostly just routine service, vehicle enhancement program (TSB fixes), and alignment. One issue I raised was a light rattle noise coming from the right/front engine bay. I noticed it after the first month of ownership, decided to wait until for first scheduled service. It's not loud, but definitely noticeable and will toggle on/off every few seconds. You can hear it outside the car. Most noticeable on cold start.
Had the shop foreman take a listen, and was told that this is the fuel pump cycling, and is considered "normal". He said to bring it back if the car does this after being warmed up, and they can run additional diagnostics to isolate the issue and take further action if needed.
Did a search on this forum and in the "known issues" thread and haven't seen one else reporting the issue. The car is a V6.
So... anyone else ever hear this sound on their cars? Appreciate any feedback one way or the other.
Thanks!
Old Jun 16, 2017 | 09:57 AM
stmcknig's Avatar
I reported something similar for my recent service and the work sheet came back with "tightened loose under tray"
Old Jun 16, 2017 | 01:02 PM
JackMac's Avatar
Took the car out today, and it definitely went away after the car warmed up.
Old Sep 28, 2017 | 08:10 PM
JackMac's Avatar
Updating this thread. The rattling noise became worse recently, noticeable with any application of the throttle. Made an appt to have both fuel pumps replaced under warranty and now problem solved.
Turns out this is a known issue, documented under TSB JTB00394NAS3 earlier this year:
NHTSA ID: 10096747
TSB ID: JTB00394NAS3
Situation: a metallic 'clicking' / 'rasping' noise may be evident from the engine is at idle speed and when the engine is cold. cause: this may be caused by a noisy high pressure fuel pump
Other than this minor issue, the car has been flawless.
Old Sep 29, 2017 | 06:43 AM
Kief's Avatar
By chance did the TSB mention V8s as well?
Old Sep 30, 2017 | 09:33 AM
JackMac's Avatar
Hey Ryan, not entirely sure. The part # for the fuel pump is C2Z31828. There are two of them, one for each cylinder bank. Both were replaced.
A search of the part # shows that it was used in the Supercharged V6 and V8 up to 2016.
Old Sep 30, 2017 | 01:08 PM
MrRay's Avatar
Hello,
I drive a V6 S MY 2018 and notice a wining sound ones the engine turns on idle after cold start.
Is this the sound you mentioned?
Cheers,
MrRay
Old Sep 30, 2017 | 02:58 PM
JackMac's Avatar
It was a rattling sound, similar to a buzzing heat shield.
Old Sep 30, 2017 | 07:55 PM
DJS's Avatar
DJS
Well, now that you describe it as a buzzing heat shield, that may be what I hear. Used to happen around 1500RPM (thus my thought that it was a resonance.) Dealer said it was the active exhaust vacuum pump, and did I want them to disconnect it? (No thanks.)
Now I hear some sort of mechanical actuator right around 1000RPM. Was going to guess squeaking active exhaust valves, though don't know why they'd be opening/closing at 1000RPM.
Old Nov 10, 2017 | 01:15 PM
Paul_59's Avatar
Banned
Doesn't seem to mention V8
File Type: pdf
Old Nov 11, 2017 | 02:56 PM
Seacourt's Avatar
I have this on my V6. Noise comes and goes at around 1500rpm and is much more noticeable with the roof up than with it down. Dealer advises they will disconnect the pump and run a line from the front of the car to activiate the vacuum needed for the Active Exhaust. Apparently a known issue and fixed under warranty.. Car goes in in a week or so’s time so will report when it’s done.
Seacourt
Old Nov 11, 2017 | 05:15 PM
DJS's Avatar
DJS
Wish I had it done under warranty. I pulled the active exhaust fuse, and the noise went away, so that confirms for me it's the vacuum pump.
Exhaust is loud all the time, which is a bit much for me.
Old Nov 24, 2017 | 07:00 AM
nurgle's Avatar
Default The noise of a rattling fuel pump!
All,
Reference this threat and the fuel pump noise. Please find attached a short video that clearly demonstrates the loud rattling noise that comes from a faulty number one fuel pump. Replaced under warranty.
Rob
File Type: zip
Old Nov 27, 2017 | 05:02 AM
Seacourt's Avatar
Default Noise has now gone
Got my car fixed under warranty by the dealer. Apparently the fix involves running a pipe from the front of the car to the Vacuum solenoid and by-passing the old Vacuum pump in the rear of the car.
All quite (at least pump wise) for now and active exhaust still works fine.
Seacourt
