Anyone know where factory horn located?
Old Apr 30, 2016 | 05:56 PM
Smoke Em's Avatar
Default Anyone know where factory horn located?
I found an air horn that I liked and all it says I have to do is find the factory horn and move the two wires from factory horn to the replacement air horn. I was wondering if anyone has put in an air horn and if it was similar in installation. If anyone knows where the horn location is. Thank you in advance
Old Apr 30, 2016 | 06:29 PM
xdave's Avatar
The horns are just behind the front grille. The best picture I could find is attached, and it is easily accessed from above by opening the hood and removing the front plastic cover. C1RH02A is the horn connector, and the harness side connector part number is XR850178 (may help you to find the mating side so you can plug in?). Pin 1 (black) is ground, pin 2 (grey with brown stripe) is connected to battery voltage via a 15A fuse and relay in the engine junction box.
Old Aug 7, 2016 | 01:14 PM
amr42's Avatar
Question
Well, I found mind here, under the right hand side plastic cover (3 plastic twirlies to remove) in front of the wind shield, with the connector loose from the body. Which hole does the connector fixing pin locate in? is it the one in between the 2 threaded holes near the top right of the photo?
Horn location
Old Aug 7, 2016 | 02:46 PM
Unhingd's Avatar
There should be two horns. Maybe there's one on the other side of the engine compartment .
Old Aug 7, 2016 | 04:05 PM
Mpowerr's Avatar
i think that may be the alarm "horn"
Old Aug 7, 2016 | 04:44 PM
amr42's Avatar
That's the one you want to hook up to the EMP device!
Harry Dredge
May 1, 2016 07:23 PM
springer
Apr 30, 2016 10:55 AM
spartan2010
E type ( XK-E )
Apr 30, 2016 06:34 AM
brinny
Apr 30, 2016 01:56 AM
Jnb6755
Apr 29, 2016 07:28 PM
