Anyone running H&R springs with a 17mm spacer? V6S specficially?
Old Jan 15, 2025 | 10:03 PM
binkyting27's Avatar
Default Anyone running H&R springs with a 17mm spacer? V6S specficially?
Been doing some research on here and it seems that for 99% of the stock wheels out there we need to get 17mm or larger spacers in order to not have to trim the stock studs.
I just lowered my car on H&R springs and was wondering if 17mm spacers will cause the car to rub, I was leaning towards 15mm to play it safer but I don't want to trim the studs
I'm on these wheels
https://www.stockwheels.com/content/...9903A_228.jpeg
Old Jan 16, 2025 | 12:15 PM
Whalesmash's Avatar
2015 R here, I had 17mm front and rears with H&Rs and had rubbing issues, mostly isolated around the rear right wheel on deep compression. It was fine on all other corners. Swapped to 15mm and still can rub if it's a really deep compression, but gone for the most part. I get the impression that the rear right is sitting a little lower than my other corners.
Old Jan 16, 2025 | 12:59 PM
darn, so you ended up trimming your studs? I wonder if the gas tank being in the rear right plays a factor in the extra weight there perhaps
Old Jan 16, 2025 | 06:14 PM
Whalesmash's Avatar
Yes, I ended up cutting the studs. It was a simple task with a $20 angle grinder off of harbor freight.
Old Jan 17, 2025 | 07:15 AM
synthesis's Avatar
I also have 17mm spacers on the rear [15mm on the front] with H&R springs and have had no issues [but did have to trim the studs]. No big deal. I don't drive my car to an extreme degree, so that might make a difference. The improved stance and handling [attenuating body-roll] made a huge difference for me.
Old Jan 17, 2025 | 12:25 PM
Craaaazzy's Avatar
One thing to also keep in mind is the manufacturer of the tire as well. The same sized tire from different manufacturers may have different measured widths.
Old Jan 17, 2025 | 08:16 PM
bfrank1972's Avatar
Keep in mind not all the stock wheels require trimming. Some have relief in the back to give room.
Old Jan 17, 2025 | 09:32 PM
OzXFR's Avatar
This has come up eleventy million times but so far the only 20" OEM wheels which fit over 15 mm spacers are the Blade wheels.
So it's not some it's one.
Old Jan 18, 2025 | 06:41 PM
bfrank1972's Avatar
Ok... I guess I somehow missed the.... eleventy million posts that you must have read, my bad, please accept my most sincere apologies.
Point is, check your wheels (including aftermarket) to see if they have clearance, you may not have to bother with the stud modification
Old Jan 18, 2025 | 07:50 PM
OzXFR's Avatar
It's not that I have read all eleventy million posts on this (close but not quite) but that I have Blade wheels and I have fitted 15 mm spacers with zero problems!
Old Jan 20, 2025 | 11:25 AM
did you go with 15 in the front because the 17s rub? or just prefer 15?
Rat Fink65
Aug 30, 2024 08:29 AM
datriani
Jun 3, 2024 07:54 PM
Obi
May 5, 2022 09:34 AM
johns55
Mar 7, 2017 05:10 AM
hawaii
Jul 28, 2013 01:22 PM
