Aquamist lines to tap
Old Mar 9, 2021 | 03:30 PM
Obi's Avatar
Obi
Default Aquamist lines to tap
Good afternoon gentlemen,
In the process of installing an Aquamist HFS-6. (Big thanks to DC the evil genius, his write up is excellent)
it requires tapping 3 signals including the
fuel injector (-). Does anybody no where to get that signal from?
Old Mar 9, 2021 | 05:03 PM
Therock88's Avatar
Can you give more info on "what" injector tap they are suggesting? Maybe paste the section to help understand...
DC
Old Mar 9, 2021 | 05:25 PM
Obi's Avatar
Obi
DC
Old Mar 9, 2021 | 05:38 PM
Therock88's Avatar
I could be reading this wrong...But here is what it looks like to me (I realize it says "Injector"...). I think it needs an ignition (Switched) + power source....A ground - source, and then the controller will be triggered for ow much the pump sprays, by the 0-5 volt signal from the MAP sensor (which you can also get from the MAPT or Accelerator Position Sensor) to determine when and how much to spray.
Now assuming I am totally wrong (and I might be)...It appears to want you to tap these signals directly from the ECU. If so, you need to splice into the ECU wiring and will need to the pinouts for the ECU. I will see if I can find that info?
Good luck. I am sure there are smarter folks on here that can steer you better.
DC
EDIT: I put the ECM etc. Wiring Diagram Here on my drive.
Old Mar 9, 2021 | 05:59 PM
Obi's Avatar
Obi
DC
Not all heroes wear capes, appreciate the info good sir
scottpeterd
Dec 14, 2020 01:33 PM
mikega
Nov 2, 2020 12:55 AM
Andreas Schmieg
Jan 22, 2018 03:04 AM
JLBolen
Nov 6, 2016 09:44 AM
rama1200
Mar 10, 2011 03:50 PM
