back speakers -- almost no output!
Old Apr 30, 2018 | 08:10 AM
pjr300's Avatar
Default back speakers -- almost no output!
So, finally, after a late spring, I'm tooling around with my F-Type, getting all the dust off the car after long winter/spring storage, checking capacities and levels, and tweaking the settings.... including the audio, which was probably prompted by my new XE daily driver.
Anyhow, as I played with the balance and fader, I realized that I have almost no output from the rear speakers. What output that is there is distorted.
So, the question: Bad amp, blown speakers, or have i something set wrong? I doubt if it's the latter, so wondering if amp or speaker failure is typical.
thx for the help!
Old Apr 30, 2018 | 09:42 AM
Unhingd's Avatar
I had the same problem on mine until I got the software update.
Old Apr 30, 2018 | 10:28 AM
pjr300's Avatar
Thx.... didn't realize that the software fix helped with this too. Is there a specific TSB that I should reference?
Old Apr 30, 2018 | 10:50 AM
RGPV6S's Avatar
thx for the help!
Mine are the same way. Almost no sound. Dealer said nothing can be done about it -twice. Mine is a 2014 S too. If you find a solution please post.
Old Apr 30, 2018 | 11:09 AM
Gibbo205's Avatar
If they are not doing much, save the weight and remove them.
Old Apr 30, 2018 | 12:28 PM
Magical's Avatar
thx for the help!
Amazing...I have a sound system ! A shout out to Daniel Luik for the answer to the fix and dmchao were correct. The bulletin was correct ( JTB00432v4 )
The interior had to be taken apart because BOTH rear sub-woofers were blown, and insulate the door speakers and rear. Configured audio amp using IDS/SDD for the software update. Both doors and parcel shelf- verified fixed. Insulator sound kit T2R21163x4 Parts T2R10501 2- T2R21202 2-T2R21163 2-T2R21164
Supposedly , it took a some time for the software update to configure. Because I have the extended warranty until 2020, no charge with exceptional service.
And for ADELE- and Earth/Wind/and Fire, Chicago, Santana, she sounds great !
Old Apr 30, 2018 | 01:50 PM
Magical's Avatar
M770 Stereo - Bass Vibration Identifed... Now to Fix...
Look for this thread above....seemed to fix Daniel Luiks stereo and others
Old Apr 30, 2018 | 04:09 PM
RGPV6S's Avatar
Could someone post the actual document for JTB00432v4? Does this version address just the vibration or the lack of output from the rear speakers too?
Old Apr 30, 2018 | 04:23 PM
DJS's Avatar
DJS
I only have JTB00432v2...
https://www.dropbox.com/s/fx74fn2exc...ystem.pdf?dl=0
Old Apr 30, 2018 | 04:43 PM
RGPV6S's Avatar
Originally Posted by DJS
Thanks for the reply DJS. I have that version from a past thread. I was wondering what the difference is.
Old Apr 30, 2018 | 07:00 PM
Magical's Avatar
This fixed everything. I FURNISHED EVRYTHING THEY DID AND PRINTED OUT INCLUDING THE BULLETIN.
Old Jun 26, 2018 | 04:12 PM
pjr300's Avatar
Well, I learned today that this work would not be covered..... my car is under the CPO warranty and not the factory warranty. Shoot!
Old Jun 26, 2018 | 04:59 PM
Magical's Avatar
pjr, I'm not sure I would be satisfied with whomever you spoke with and would try again with the manager.
I had this fixed in APRIL ! And as Unhingd said, it needed the software update.
Old Jun 29, 2018 | 04:36 PM
pjr300's Avatar
Well, I tried again today, same dealership, different adviser, same answer. CPO does not qualify for audio warranty, not even the TSBs.
May try another dealer.
Old Jun 29, 2018 | 06:28 PM
bjg625's Avatar
Make them show you where it says that, Since when are TSB's a warranty issue?
Old Jul 3, 2018 | 09:34 AM
rexus31's Avatar
Is there a way to check if a certain VIN received the work per the above referenced TSB? I've got 6 months left on the initial factory warranty (CPO warranty after that) and if my car has not been serviced per the TSB, I'd like to get it done.
Old Aug 10, 2018 | 03:24 PM
pjr300's Avatar
Brought it to the dealer again --- they are telling me that the JTB 00043v4 is for the rattle..... not for the low back speaker output. HELP! Can anyone provide something that io can counter with these folks? It's in the shop now.
David's XKR
Jun 10, 2016 07:09 PM
731Loadmaster
Nov 9, 2012 01:49 PM
IrishXtype
Jan 15, 2011 10:58 AM
