Base 2015/2016 question
Old Apr 9, 2018 | 06:25 PM
maxiedaniels's Avatar
Default Base 2015/2016 question
I'm considering a base 2015 or 2016 F-Type coupe, but I'm confused on the active exhaust stuff. I'm fine with the car being loud all the time - is that the case if I don't get active exhaust? As in, would the barebones base sound the same as a higher end model with the 'loud' button pressed?
Old Apr 10, 2018 | 05:51 AM
Unhingd's Avatar
The active exhaust with the valves open is marginally louder than the base exhaust. (Not enough to worry about)
Old Apr 10, 2018 | 08:50 AM
DJS's Avatar
DJS
Keep in mind there's active exhaust, then there's switchable active exhaust.
Old Apr 10, 2018 | 08:59 AM
ek993's Avatar
Yep, active exhaust without the button = no opportunity to make it loud all the time (without pulling fuses or some other type of modification).
Old Apr 10, 2018 | 10:17 AM
Interesting.. so active exhaust without switchable means it only triggers at high revs or something?
and it’s only a bit louder than normal base with no options?
Old Apr 10, 2018 | 11:37 AM
ek993's Avatar
Yes the valves will only activate under heavy acceleration, otherwise its pretty quiet.
Old Apr 10, 2018 | 01:01 PM
El Gato's Avatar
The 2016's provided switchable exhaust on the base model and the 2015's did not - I think it was an option in 2015?
My 2016 gets much louder in Dynamic driving mode than switchable activated alone so the 2015 may be the same.
Old Apr 10, 2018 | 01:17 PM
NigelW's Avatar
My 2015 sticker, the Switchable Active Exhaust was a
n option.
Old Apr 10, 2018 | 01:20 PM
DJS's Avatar
DJS
That's quite a sticker. Former contributor Foosh insisted that the base without active exhaust was loud-ish all the time, and thought that active exhaust allowed it to be quieter at times. I haven't heard a base (much), so I can't comment.
With non-switchable active exhaust, using the paddles lets some more fun out of the tailpipes.
Old Apr 10, 2018 | 07:22 PM
Unhingd's Avatar
They open at 4000rpm regardless of acceleration or throttle position.
Old Apr 10, 2018 | 07:41 PM
ek993's Avatar
Interesting, thought it required a heavy right foot as well being up in the rev range.
Solution - drive everywhere in 2nd gear 😀
Old Apr 10, 2018 | 08:24 PM
Unhingd's Avatar
Of course, under full throttle, the sound is much more pronounced, but the valves are open either way over 4k.
Old Apr 10, 2018 | 10:28 PM
DJS's Avatar
DJS
Without switchable, they can't make up their mind at 1800rpm, as my squeaky valves have shown.
Old Apr 11, 2018 | 03:49 PM
Unhingd's Avatar
Is it throttle position dependent, or always at 1800 rpm?
Old Apr 11, 2018 | 03:57 PM
DJS's Avatar
DJS
I haven't had the fuse in since last fall, but my memory is that whenever the revs cross 1800rpm, I'd hear the valves either open or close. Been meaning to put the fuse back in - hope the valves haven't seized up.
Old Apr 11, 2018 | 04:00 PM
Selko92's Avatar
The exhaust is much louder in Dynamic mode then in regular mode with active exhaust enabled. Pretty big difference to me.
Old Dec 6, 2020 | 06:48 AM
Iandallas's Avatar
I purchased 2015 v6 base recently. I don't have the active exhaust button, but can hear the snack, crackle, pop around 4k rpm. I'm satisfied.
Old Dec 6, 2020 | 07:30 AM
Carbuff2's Avatar
Same here...
mclarenf1lmguy
Aug 27, 2017 12:00 PM
pnd4pnd
Dec 26, 2016 06:39 PM
jfranks
Dec 4, 2016 09:20 PM
supercat'dXKR
Jun 6, 2016 10:35 AM
SCMike
Dec 29, 2015 06:19 PM
