Battery low signal
Old Mar 31, 2025 | 10:21 AM
Bearly's Avatar
Angry Battery low signal
My 2016 F Type R has recently been positing a "low battery warning, please start vehicle", on my dash as soon as I enter the car. This morning, after leaving it on the charger all night, and seeing a green light on the charger panel, it immediately gave the same warning. Since I know the battery was fully charged, what could be causing this indication?. Thanks for any clues.
Old Mar 31, 2025 | 10:26 AM
Gearhead01's Avatar
How old is the battery? An older battery may not be able to maintain the proper voltage to meet all of the finicky F-Type electrical system needs, even after being charged.
Old Mar 31, 2025 | 10:39 AM
cpq100's Avatar
Does the hazard warning triangle on the dash go out after the car has been shutoff for ten minutes? If not the battery is being drained. To correct the issue you need to disconnect one of the battery leads for a minute.
Old Mar 31, 2025 | 12:42 PM
eeeeek's Avatar
The best question to ask is 'did someone plug something into the obdii port recently? A dealer? A smog check? Yourself?" The vast majority of time, it' simply that someone didn't exist an obdii session correctly and that leaves the car in a state with a parasitic drain that will kill the battery in less than a week. The dealer caused this on my car twice.
Old Mar 31, 2025 | 02:28 PM
JagCode3's Avatar
@Bearly Invest in a BT battery monitor. Takes 5 minutes to install across the terminals and will let you know exactly what is going on. I have an Ancel300Pro but there are cheaper ones on Amzn. It showed me that every time I unlock the car or open the door the voltage drops by 0.5V immediately even after full charging. Please report back.
Old Apr 1, 2025 | 07:01 AM
TangledThorns's Avatar
Have a dash cam installed? My dashcam (DroneXC) has a constant phantom drain on my battery, ugh.
Old Apr 1, 2025 | 04:31 PM
Evoex's Avatar
Yeah I wanted to avoid that issue completely, I went with a battery pack addition. Camera is wired to battery pack, battery pack hardwired into the fuse box. Battery pack only charges when engine is on.
Old Apr 3, 2025 | 12:59 PM
Bearly's Avatar
I checked the battery both running and engine off. It retains 12.6VDC at rest, and 14.4VDC while running. I replaced bank two sensor one O2 sensor after getting a light on the dash, and that was the code at the port. I don't know the age of the battery, but if it's keeping voltage at rest, I assume it's decent. Any other ideas?? LOL
Bearly's Avatar
Nope
Old Apr 3, 2025 | 01:00 PM
Bearly's Avatar
Disconnecting the leads does what for the issue?. I'm confused.
Old Apr 3, 2025 | 01:23 PM
cpq100's Avatar
It corrects a fault that occurs when the ODBII port is accessed and the session is not shut down correctly. That fault causes the battery to be drained. The telltale sign the fault is occurring is the red warning triangle on the dash never goes out. Disconnecting one of the leads solves the issue temporarily until the next time an ODBII session is not ended correctly.
Old Apr 3, 2025 | 06:56 PM
JagCode3's Avatar
@Bearly This is a BMS issue. Disconnect the negative lead at the battery for a few minutes then reconnect.
Your battery and alternator are otherwise normal based on your voltages. Thanks for checking.
If that doesn't work, time to check for errors using your OBD2 reader and clear them.
Old Apr 4, 2025 | 07:26 AM
dennis black's Avatar
You have to reset the bms with a scan tool
I'll be posting another video of my wife's F-type R Maintenance and Battery info, I'm putting a Stage 4 for here
Old Apr 4, 2025 | 12:45 PM
Bearly's Avatar
Default Thanks buddy.
It has disappeared for now, so I guess it corrected itself?. LOL Thanks for your comment.
Old Apr 4, 2025 | 12:47 PM
Bearly's Avatar
Thanks, it seems to have corrected itself for now.
Old Apr 4, 2025 | 12:50 PM
Bearly's Avatar
I noticed in your pictures an Isoft scanner V3.0, however, I looked these up and they're specified for Porsche, is that sequestered for Porsche only, or is it available to all makes?. Just curious.
Old Apr 4, 2025 | 01:07 PM
DJS's Avatar
DJS
Here’s the JLR version. I got mine off Amazon.
https://www.icarsoft.com/Product/s-3...verjaguar.html
Old Apr 5, 2025 | 11:49 AM
Bearly's Avatar
Default hmm
Thanks for the link, but when I clicked on it, it warned me about a security risk. Oh well, I'll look for it on amazon myself. Good day
Old Apr 5, 2025 | 12:19 PM
This ICARSOFT v3 is specific for Jaguar/Range rover
alanroberts50
Nov 23, 2024 03:40 PM
Rat Fink65
Sep 12, 2024 06:55 PM
Holein1
Oct 9, 2023 03:53 PM
nightfall
XF (X260)
Mar 20, 2023 12:39 PM
TXJagR
Mar 12, 2016 11:12 AM
