Battery thing getting annoying
Old May 18, 2016 | 04:41 PM
IRRBrogue's Avatar
I bought a cheap ($1.61!) voltage indicator to plug into the 12v port in the center console. Yes, it does stay on, for a while, but eventually that port turns off. No reading until I open the door, then it wakes up, and usually shows about 12v. I have seen 10.5v for a short time while cranking, and 14.3v or so at times while charging. I did the disconnect (thanks Unhinged) and solved my early problems.
Old May 18, 2016 | 09:45 PM
mjm3457's Avatar
Originally Posted by Nati
The 12v in the center console is definitely not hot in my car when the car is shut down. However, it turns on when you unlock the car. Goes to sleep once you lock.
I haven't used the one in the center stack for this purpose however.
Ah, so! Yes, the cigarette lighter socket behaves the same way; once the car is locked, it is off. Thanks; I learned something.
Old May 24, 2016 | 07:40 AM
Grumpy Finn's Avatar
Just told my dealer "Please, do not make me go to Batteries + and buy a new battery", getting the same old runaround, with a twist "It is normal to get the, battery low start the car message, every now and then" I started laughing....
Old May 24, 2016 | 05:44 PM
Vroooom's Avatar
I have a new car with 100 miles driven so far. Went to the garage after not driving it for a few sprays and it is dead!
Old May 24, 2016 | 05:48 PM
TimelessR's Avatar
Just wait until you get to the dealer.. they will say they can't detect any problem and need to reproduce the problem before doing anything.
Old May 24, 2016 | 06:31 PM
Unhingd's Avatar
They probably tapped into the obdII to prep the car. Disconnect the battery for at least 10 seconds and the energy control module should reboot itself and solve the problem.
ImNotFamousAnymore
Feb 12, 2026 06:38 AM
Fstbmw1
Sep 5, 2021 01:29 PM
AnD3rew
Apr 11, 2016 09:54 PM
Rhett
Apr 6, 2016 08:03 AM
DanielSWE
Mar 28, 2016 06:22 AM
