Blackvue Dashcam install
Old May 25, 2016 | 07:38 PM
Nati's Avatar
I considered blackvue but ultimately went with Street Guardian SG9665GC due to superior image quality, especially at night. Downside is no wifi downloads...have to pull the SD card to transfer...and the GPS is a plug-in dongle. Happy with it so far. I did order a polarized lens filter for it to cut down on windshield glare & reflections.
Old Jun 25, 2016 | 11:00 PM
CRS 123's Avatar
I've had the same camera (Blackvue) for about a year...great camera. Just switched it to my 2017 XE R Sport. Same location as you. I've found though, that because of the UV blocking windshield, I can,t get GPS data. Not that big a deal. So you get GPS with your setup?
CRS
Old Jun 26, 2016 | 08:08 AM
RawwR's Avatar
CRS
I've since swapped to a 2016. The 2015 had a heated windshield and GPS was not an issue. I'm having issues with the dealership and my use of the ODBII / DLC port for radar detector power and haven't installed it in the 2016 which doesn't have the heated windshield. Where ever you decide to draw power from, verify that the car will hibernate by checking the hazard light goes out. If not you could end up with a dead battery.
Old Jun 26, 2016 | 08:43 AM
Adz3000's Avatar
CRS
Didn't know it would block GPS but i'm pretty sure i read somewhere that there is a portion of the UV windshield that is normal to allow for toll booth passes.
Although it's probably most likely that this position is no good for a dash cam.
Old Jun 26, 2016 | 12:07 PM
CRS 123's Avatar
Yes...good advice. Power to the 12V ports starts when vehicle is unlocked, and turns off when car is locked.
Old Jun 26, 2016 | 12:10 PM
CRS 123's Avatar
Yes...the small areas which have black dots by the review mirror do not restrict RF...best place for transponders, but not a good location for dash cams.
CRS
Old Jun 26, 2016 | 12:13 PM
CRS 123's Avatar
Yes....be mindful that behind the windshield radar detectors like Redline etc, their performance will be seriously degraded by UV windshields. I'm join to try and mount my redline up high behind the black dots, and detest how well it "sees" from there. The best bet for radar would be a remote mounted outside like the STiR plus from Beltronics....a great unit I had on my other car.
CRS
Old Jun 26, 2016 | 12:45 PM
  #28
Nati's Avatar
I've been having trouble with my radar detector and it is mounted in the "clear" zone on the driver's side of the rearview. Interestingly it gets GPS lock much faster than it did in my XF, but it has obviously deteriorated radar detection.
Old Nov 2, 2020 | 12:21 AM
Raymond3's Avatar
CRS
Did you hardwire it?
mhamilton
24
Jun 15, 2017 03:51 PM
Hoppy
Feb 24, 2016 03:50 PM
Kopi
Feb 19, 2016 08:41 AM
superA
Feb 5, 2016 08:21 PM
rhscare
Feb 5, 2016 02:21 PM
