BMS battery discharge - objective data
Working on the actually solutions in the codding for this, pretty complicated but I think it's doable. In the meantime can everyone running with BMS off chime in on the behavior you guys are seeing ?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
I gave up on disconnecting the BMS so @chasers03 will have to chime in - as I mentioned earlier, he is the pioneer.
Must have missed my post, I've already been working on CCF changes related to this.
I have several months ago disconnected my 2016 R Coupe Jag BMS and I [including the Antigravity folks] like reading a constant charge of 93 to 99% & 13.76 V level on my AntiGravity battery tracker app. However I don't like seeing the battery charging fault signs on the dash [I often tap menu and the main, most annoying warning light goes away]. I always [43,000 mi] have a full battery when I start up... It sounds like you 71Camaro have eliminated the charging fault warnings by modifying the BMS coding in the Car Config. File. with a GAP IID tool. Soooo now I guess I need to purchase that tool and somehow modify that BMS coding....71Camaro can you dumb this process down for me? My only goal is to abolish the battery charging warning lights...I'll randomly run Antigravity Battery App for that charging health check....
I thank you for your efforts and trust that you will be able to communicate how to do it once you get it right thank you
Messing with binary files is not something to take lightly and not for your avrg enthusiasts. I do it on regular bases since that's what we do when we do ECU tuning . If we're able to get this done properly will release it as part of the tuning solution which can be easily done with our handheld device through and app on your phone in and in your driveway, just like we ramap for power.
__________________
Definitely intrigued by the CCF editing, I have Jaguar SDD but didn't find anything obvious there. Will look into the CCF editing myself.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
