bought a salvage 2015 v8s
Old Mar 3, 2017 | 07:34 AM
mark campbell's Avatar
Default bought a salvage 2015 v8s
well received my cali car Tuesday .its not what I hoped but that's how it goes .going to need a lot of advise from you folks here --will post some pics asap. first question I have is what is up with the oil .I have had or have a few jags (+- 10) but all with 4.0/4.2.what has happened to the good old dipstick .took a lot to make sure I had any engine oil .so I could start engine after I charged the battery. just seems overly complicated to just change oil .
Old Mar 3, 2017 | 07:45 AM
Stohlen's Avatar
If you think it's overly complicated changing the oil you're gonna be in for a surprise trying to fix the rest of the car. Hopefully you don't have any body damage, because that's gonna be very difficult to repair.
Oil change on this car is just like any other car except there's no dip stick. You check oil level on the cluster.
Old Mar 3, 2017 | 07:52 AM
Mueller's Avatar
Trying to repair an all aluminum car sounds like an absolute nightmare. Good luck. Post pics of the car before you start anything.
Old Mar 3, 2017 | 10:19 AM
SinF's Avatar
It could be flood salvage?
Old Mar 3, 2017 | 10:22 AM
Dogbreath!'s Avatar
Can you use caps at the beginning of sentence and break text into paragraphs as appropriate? Sorry, but I write and edit as a job and am really **** about it.
Old Mar 3, 2017 | 10:41 AM
SNG Barratt USA's Avatar
Former Sponsor
Please give us a call if you're looking for any parts!
We have a number of slightly used panels such as hoods, doors, fenders etc for F-Types in various colors.. Plus wheels, mirrors, lights and such.
Old Mar 3, 2017 | 12:40 PM
Unhingd's Avatar
Since the car will have a dramatically reduced resale value, you should turn it into a proper project:
620+HP pulley/tune
Weight stripping campaign (Ti exhaust, cf wheels, airbag delete, seat & battery swap, etc.)
6 speed Tremec
Lowered suspension
Etc.
Old Mar 3, 2017 | 01:13 PM
Tel's Avatar
Tel
620+HP pulley/tune
6 speed Tremec
Lowered suspension
Etc.
Yes, what Unhinged said! or turn it into an out and out GT racer!
Also, try using the 'Search' feature within the threads...the subjects of oils/dipsticks have been done to death, and there is lots of great information to be had.
Old Mar 6, 2017 | 12:54 PM
Default pic
Old Mar 6, 2017 | 01:28 PM
Stohlen's Avatar
That sure doesn't look like it has an engine in it... that or there's something significantly wrong with the cradle
Old Mar 6, 2017 | 02:09 PM
Tel's Avatar
Tel
Got air ride or Hydro on it
Old Mar 6, 2017 | 08:30 PM
Unhingd's Avatar
+1. If the engine is still in it, the work needed on the unibody will cost more than a used car in pristine condition.
Old Mar 7, 2017 | 03:30 AM
Default these are the pics on which i bought the car
Attached Thumbnails bought a salvage 2015 v8s-f-type-2.jpg   bought a salvage 2015 v8s-f-type-3.jpg   bought a salvage 2015 v8s-f-type-5.jpg   bought a salvage 2015 v8s-f-type-6.jpg   bought a salvage 2015 v8s-f-type-7.jpg
Old Mar 7, 2017 | 03:40 AM
AnD3rew's Avatar
Eek, you may be ok if there is only panel damage on the hood, nose and fenders and bolt on suspension components but if there is any chassis damage it is going to be bad. And unfortunately I think there is no chance there isn't.
OzXFR's Avatar
Looks to be way too much panel and structural damage to make it a doable cost-effective repair.
But there could be a profit in parting it out, in particular the engine and transmission (if undamaged) and the seats.
Old Mar 7, 2017 | 03:52 AM
sorry abought the delay yesterday was very hectic /and have head cold.car is worse than it looks .suspension is completely gone.i can salvage the shock,rotor,and caliper---maybe the front vertical link(boomerang) and the sway bar link that all.engine cradle is missing sections and cracked /torn in several places.worst of all is the lower beam its trash(well somebody already tried to work on it / hack on it !!!!!!!!!!!!!!!!).but that's the ok part .bad part is the missing pieces .I have a busted radiator and cooling fan ....that's it .no ac,power steering,supercharger,transmission all missing .even the door speakers are missing.--well the good news engine and transmission work hence my oil question (did't care about the oil level just wanted to be sure it had any oil in it while it was on the ground so I could start it).cobled together the brake and suspession (I have a few modern jags)so I could drive it on my lift ---and here we sit ....pics to come shortly--------------ps I'm not a very good writer so please have patient's with me
Old Mar 7, 2017 | 05:40 AM
and yes barret I will need a part or two ---thanks for the invite
Old Mar 7, 2017 | 10:02 AM
WhiteTardis's Avatar
If you do decide to part the car out, I'll be happy to take some interior bits off the car.
Old Mar 7, 2017 | 10:07 AM
DirtyAir's Avatar
I'm in to see the final product and project pictures. You are more patient than me.
Old Mar 7, 2017 | 10:50 AM
17jag's Avatar
Default Good luck
i wish you all the best here. I just bought a 17 F type so did a lot of reading prior so understand this will get complicated. Lot of respect for you, for taking this on. It will be a challenge.
