Brake Questions
Old Jun 11, 2024 | 06:56 AM
Spyderturbo007's Avatar
Default Brake Questions
I have a 2017 British Design Edition which has the 380mm front and 376mm rear brakes. I just started getting a squeal and am assuming I'm going to need brakes. I was considering doing it myself, have a few questions and was hoping someone could help.
1. What's the easiest way to tell if I need brakes or if this is just pad squeal and the plate needs some anti squeal lube? I read there were sensors for the pads, but I'm not 100% sure on that one.
2. Are there ceramic pad options for this car?
3. Is it necessary to replace the rotors at the same time, or can I just measure the thickness and compare it against a specified tolerance somewhere?
4. If I do need rotors, are there options as good or better than what I'd get from the dealer, or is the dealer the best option?
5. Is brake maintenance mode only required for the rear brakes, or is that for the front as well?
6. Is it alright to push fluid back through the master cylinder when compressing the calipers? Can I just use the old C-Clamp method to get them closed?
As for tools, it looks like the only thing I'd need out of the ordinary is a 9mm torx. The last time I did pads / rotors was probably 10 years ago, but I can't imagine a ton has changed.
Thank you for the help!
Old Jun 11, 2024 | 07:31 AM
OzXFR's Avatar
The best way to check if you need new pads or not is to remove the pads from the calipers and inspect them. Anything less than around 3 mm thickness and they need replacing. You could at a pinch look at the edges of the pads through the gaps in the calipers and guess the thickness but that would be a bit hit and miss. There are brake wear sensors plugged into two of the eight pads, inner pad left front and inner pad right rear, and they are supposed to trigger a "brake pads low" warning on the dash if the respective pads gets to 2 mm thick but they are problematic and don't always work properly and you can't tell which of the two has triggered without going back to square one and removing the pads anyway. If you need or want new pads they are relatively easy DIY job.
Yes, EBC Redstuff are one but many here including me have fitted Porterfield R4-S pads and been very happy with them. Not ceramic as such but carbon/kevlar but they perform and work the same as ceramic pads.
Not unless the rotors are worn below minimum specified thickness which is 34 mm front and 24 mm rear, or they are badly chewed up or gouged. Easy enough to measure the thickness with a Vernier caliper.
Dealership is a good option only if you wish to pay through the nose, plenty of perfectly good aftermarket options costing waaay less, R1 Concepts is popular around here.
Yes, rears only.
Yes as long as you first make room in in the brake fluid reservoir by sucking some out, eg with a turkey baster or syringe. But don't remove too much, leave an inch or two in the reservoir and recheck the level as you do each wheel. C-clamp (I call it a G-clamp) works just fine, I have used one many times with no problems. On the F-Type there is a procedure to put the rear brakes in "service mode" (a sequence of button presses) which retracts the brake pistons, see your Owner Manual or the Service Manual.
9 mm hex (not Torx) for the front caliper slide pins and 7 mm hex for the rears.
See above for my 2c worth.
Old Jun 11, 2024 | 11:06 AM
uncheel's Avatar
Second all that OzXFR suggested (great source). It would have been helpful to know your mileage - not a true substitute for inspection, but would help gauge the likelihood of needing to replace pads/rotors. On a MY17, I'd guess pad, yes; rotors, doubtful. Don't break the bank thinking ceramic. Porterfield's are great. Good self-maintenance project. You'll find instructions in the "How To" sticky thread, including the point about pulling off a bit of fluid while you're compressing the system - but not so much that you risk letting air into the line.
Old Jun 11, 2024 | 01:16 PM
RGPV6S's Avatar
If you measure the disc thickness make sure you use a micrometer toward the middle of the disc and not a caliper at the edge. There will be a lip around the edge of the disc making it appear thicker than it really is.
Old Jun 11, 2024 | 07:17 PM
diablo2112's Avatar
I did the brakes on my 2017 R. Same size as yours. Dealer wanted $3,500. I paid $800 for drilled/slotted rotors and ceramic pads, and it took about 2 DIY hours in total. Easy job with a floor jack.
https://brakeperformance.com/brake-r...nc-coating.php
Old Jun 11, 2024 | 07:35 PM
OzXFR's Avatar
OP - just beware the brake pads shown in that listing are semi-metallic not ceramic.
One of the main reasons for switching out the OEM semi-metallic brake pads for ceramic (or Porterfield carbon/kevlar) is the massive reduction in brake dust, semi-metallic pads are notorious for being very dusty and the OEM Jag pads are among the worst.
I have found over the years that when buying a kit of rotors and pads even if the pads are advertised as ceramic quite often they are not and they are still semi-metallic.
For that reason I never buy such a kit instead I buy the rotors and pads separately and that way I get what I am after.
Old Jun 11, 2024 | 11:31 PM
diablo2112's Avatar
You can select ceramic pads on that page. They offer both semimetallic and ceramic. I ordered the ceramic. 4000 miles later and I'm very pleased with the lack of dust. Working great.
Old Jun 12, 2024 | 01:47 AM
OzXFR's Avatar
Yep, I see that now (after clicking through a few boxes).
Thanks for the link, great price (especially with free shipping for those of you in the US), I will check them out again when I next need new rotors.
Old Jun 12, 2024 | 07:43 AM
Thank you to everyone for the help. I haven't done a brake job on a vehicle in probably 10 years and wanted to make sure there wasn't something unusual I needed to know.
@diablo2112 I appreciate the link I was hoping for ceramics because the brake dust is insane on these things along with the exhaust soot all over the back of the car. I'm going to measure the calipers first and make sure it's necessary before ordering.
Old Jun 14, 2024 | 06:47 AM
Is this pretty much what everyone buys? My rotors measure at barely under 35mm in the front and 25mm in the rear. So I'm thinking I should probably just replace them when I do the brakes.
Old Jun 14, 2024 | 07:17 AM
OzXFR's Avatar
That puts both front and rear at 1 mm thicker than specified minimum thickness.
However those specs are incredibly conservative and a whopping 2 mm less thickness than brand new rotors, so barely worn at all.
I have said it before but I reckon those minimum thickness specs are a bit of a con, designed so that JLR dealerships can recommend/insist on new rotors when they are not really needed, and charge like a wounded bull for the privilege.
An alternative argument is that the minimum thickness specs are set so that it's OK to continue to use the same rotors at your exact measurements (1 mm more meat than minimum) for another set of pads worth because the real/true minimum thicknesses are really at least 2 mm less than spec.
Have you seen how thick the rotors are, especially the fronts? No way in the world are they worn out / unsafe at 2 mm less than new thickness!
Bottom line - your choice whether or not to change rotors as well as pads but you will be perfectly OK to use the existing rotors for another set of pads.
Old Jun 14, 2024 | 11:21 AM
Awesome. Thank you @OzXFR Everything you said makes complete sense. I'm just going to go with pads in that case.
Adam78
Mar 29, 2018 01:22 AM
Mark in Maine
Jul 2, 2016 10:08 AM
jfintexas
Sep 12, 2013 03:36 PM
craig76
Sep 8, 2013 05:09 PM
Uptown Girl
Oct 14, 2008 05:56 PM
