Bumper question
Old Dec 24, 2019 | 11:56 AM
pjazz's Avatar
Default Bumper question
I have a question regarding the Black center piece "I have a white car" below the bumper above the air dam. Mine has some scratches at the bottom of it and was wondering if the screws under it will allow me to remove it for refinishing?
Old Dec 24, 2019 | 12:57 PM
Carbuff2's Avatar
Is it painted black, or 'natural' black plastic (uncoated)?
Old Dec 24, 2019 | 01:23 PM
pjazz's Avatar
You tell me.
Old Dec 24, 2019 | 02:22 PM
sov211's Avatar
Originally Posted by pjazz
You tell me.
Although it looks to be simply shiny plastic, it is indeed painted in high gloss. This I found out to my dismay as I attempted to wet-sand out some blemishes...
Old Dec 24, 2019 | 02:44 PM
pjazz's Avatar
Just wondering if it is easily removed so i can maybe get a collision shop to paint. Or is there a replacement part number that already painted?
Old Dec 24, 2019 | 02:58 PM
Unhingd's Avatar
Can be unbolted with bumper skin removed from car.
https://parts.jaguarreno.com/oem-par...MtMGwtdjYtZ2Fz
Old Dec 24, 2019 | 03:00 PM
pjazz's Avatar
Thanks. You found it the same time I did. Are you saying I can't just remove the piece by it self?
https://parts.ftmyersjaguar.com/oem-...MtMGwtdjYtZ2Fz
Old Dec 24, 2019 | 03:23 PM
OzXFR's Avatar
Aha, you are talking about THAT piece!
I thought you were talking about the centre bar across the middle of the grill, and I think a few others did as well.
That lower splitter/deflector is fairly easy to replace, I replace mine over two years ago when the original piece was holed by some metal road debris.
No need to remove the bumper, instead you do it from underneath after removing the front plastic undertray and the seconday "box" undertray which sits under that.
It's held on by five (maybe six?) torx screws (T20?) along the back edge, you can just get to them from underneath with a longish screwdriver.
One main tip (thanks xdave!) is make sure you heat up the new piece with a hair dryer just before you fit it, as you need it to be "bendy" for the mounting holes to line up, it's too stiff when stone cold for this.
JensenHealey
Oct 24, 2016 01:25 PM
jaguarturk
May 21, 2015 06:32 PM
para911
Jul 19, 2012 08:18 AM
GhostriderXKR08
Feb 21, 2011 01:42 PM
