Car Always Starts In Second Gear From Stop?
Old Apr 9, 2017 | 07:17 AM
AJF's Avatar
AJF
Default Car Always Starts In Second Gear From Stop?
I just bought my car last week and still poring over the manual but I can't seem to find out why when I take off from a dead stop, it always does so from second gear rather than first. Is this normal?
Old Apr 9, 2017 | 07:29 AM
Arne's Avatar
In "normal" mode it is absolutely normal. I don't remember what happens when you set in in sportsmode or dynamic mode, as I tend to use those modes when "on the run" and not so much stop and go.
Old Apr 9, 2017 | 09:47 AM
kamiar's Avatar
That's normal in economy mode, should start in first in sport mode, just a fuel saving trick
Old Apr 9, 2017 | 10:04 AM
Jabooh1's Avatar
Do you have it in winter mode?
Old Apr 9, 2017 | 10:34 AM
AJF's Avatar
AJF
It's not in Winter and I usually drive it in Sport. I'll check again when I go out later.
Old Apr 9, 2017 | 06:34 PM
Timbo's Avatar
My R starts in 2nd in every mode.
Old Apr 9, 2017 | 07:01 PM
Mark G's Avatar
Yup. I have to downshift to 1st if I want to start there from a stop even in manual mode.
Old Apr 9, 2017 | 07:13 PM
JD83's Avatar
My 14' v8 vert starts in 2nd as well in all modes as well.
Old Apr 9, 2017 | 07:25 PM
OzXFR's Avatar
Discussed to death on another forum I inhabit, but the general consensus is that it starts in 2nd gear no matter what mode you are in unless you manually downshift to 1st gear using either the left paddle, or the gear stick if in S mode, OR you hit the go pedal hard enough on take off to hit the kickdown switch, in which case it kicks back to 1st gear.
Old Apr 9, 2017 | 08:01 PM
Unhingd's Avatar
Pretty much all ATs started out in 2nd since the 50's unless the throttle was to the floor.
Old Apr 9, 2017 | 08:03 PM
Mark G's Avatar
But in manual mode it should go to 1st.
Old Apr 9, 2017 | 08:07 PM
OzXFR's Avatar
Nup, not on my S it doesn't, unless as I said above I either knock it back to 1st using the left paddle or the stick, or I flatten the go pedal.
Old Apr 9, 2017 | 08:10 PM
Mark G's Avatar
What I'm saying is that it should go to first, but it doesn't. That was in response to the previous post about how automatics always start in second. In manual mode, they should go to 1st. I think even my X5 goes to 1st in sport and manual mode.
Old Apr 9, 2017 | 10:05 PM
DirtyAir's Avatar
Have you actually run off a light in first? It's worthless unless you can feather it for an extra 1/10th (guessing) or to bang the rev limiter through the intersection. My tires want to spin in 2nd without being aggressive. I can't imagine all the complaints if she started in 1st.
Old Apr 10, 2017 | 12:12 AM
HalcyonDays's Avatar
In Dynamic/Sport/Manual I almost always start in First gear. Easy to control and allows me to relive my misspent youth.
Old Apr 10, 2017 | 12:33 AM
bjg625's Avatar
Mine starts in 2nd in norm and first in dynamic, pretty normal today. Our Maser has same trans and does the same thing, my '12 SLK55 did same with merc 7sp.
Old Apr 10, 2017 | 01:01 AM
u102768's Avatar
My 07 XKR starts in 1st in both D and Sports Mode regardless of throttle angle.
It will only pull away in 2nd if I have been using the flappy paddles and haven't changed down manually.
Old Apr 10, 2017 | 05:44 AM
AJF's Avatar
AJF
Wow, longer thread than I expected lol. I do prefer to start off in first when I really want to take off. I agree that it should go down to first when in sport, my Maserati does but then it only has 6 gears.
Old Apr 10, 2017 | 10:37 AM
Mark G's Avatar
Yes, I do it frequently when the roads are clear. It takes off without a chirp. AWD for the win!
Old Apr 10, 2017 | 10:59 AM
DPelletier's Avatar
....I start in first with the paddles in my RWD too.
Dave
