Car jerks when put in drive every morning
Old Apr 7, 2016 | 08:11 AM
  #61
ek993's Avatar
I have 14k miles on a V8S that has been my daily driver for 2 years. I have absolutely no shunt / jerk or any type of sensation when putting the car into D when starting up in the morning. This absolutely would not be normal behavior.
I used to own a BMW 335i that also had a ZF gearbox (albeit totally different unit to the F Type). This gearbox had a well documented problem with the mechatronic unit that gave exactly these symptoms - a thud as you engage D, almost as if you have been hit from behind. My car had this problem. Just do a search for "BMW 335i mechatronic problem.
Not saying that is the case with this gearbox, however just using it to illustrate some units may develop problems that other owners don't experience.
Old Apr 7, 2016 | 09:05 AM
  #62
SinF's Avatar
One of my classic cars kicks like a mule when put into reverse when cold. My understanding is that in that case it is tied to engine RPMs. Higher RPMs, more it kicks. When warm, and with low idle RPMs it shifts smoothly.
Considering that F-type, when started cold, will have about 15 seconds of 'warm up' high RPMs, have you tried waiting until it drops to normal mode to see if it still kicks?
Old Apr 7, 2016 | 04:41 PM
  #63
Overblown's Avatar
I think we have already established that for several of us, it is not an rpm related issue. There is something else that is causing it that has nothing to do with engine speed. It only happens if the it's been sitting overnight/several hours. If it's sat for a few hours, long enough to cool to the point where it high idles upon startup, it doesn't do it.
Old Oct 15, 2016 | 04:46 AM
  #64
CaptainHam's Avatar
Just found this on Topix...technical bulletin JTB00498, does this apply to your VIN?
Old Oct 27, 2016 | 04:54 PM
  #65
jallitt's Avatar
My vin is just before that range but I assume the same "engagement strategy" applies. it's nice to know we're probably not imagining it.
I'm booked in for a service next week so I'll mention the TSB to the service manager.
Old Oct 28, 2016 | 03:59 AM
  #66
CaptainHam's Avatar
Mine hasn't done it in ages, but since finding that bulletin, it occurred to me that it last happened last winter...so if it starts happening again this winter, then that fits nicely with the problem description in the bulletin. Will find out soon enough.
Old Oct 28, 2016 | 02:06 PM
  #67
carzaddict's Avatar
i felt this on pretty much all my jags AND bmw
Old Jan 27, 2019 | 11:31 AM
  #68
Diorama Sky's Avatar
So did anyone ever take their car in to the dealer to show them this TSB? Just curious what happened?
Old Jan 27, 2019 | 12:33 PM
  #69
Unhingd's Avatar
Just let the clutch out more slowly.
Old Jan 27, 2019 | 12:47 PM
  #70
CaptainHam's Avatar
Mine stopped doing it after a while. Must be at least 2 years now and it's never reoccurred.
Old Jan 28, 2019 | 12:03 PM
  #71
StormtrooperFtype's Avatar
Originally Posted by perfectson
anyone else encountering this issue. CAr jerks pretty hard every morning
Mine does it too on cold starts if I don't wait about 10 seconds, ive gotten used to it.
Old Mar 17, 2019 | 12:02 AM
  #72
In case anyone is curious, I took my car to the dealer with the TSB, and they "fixed" it with a software update, but it definitely still does it.
Old Apr 2, 2019 | 09:52 AM
  #73
FullChat's Avatar
2017 Base Unicorn here. I do not wait for the idle to settle down, just take my foot off of the brake and go into reverse, no jerk, just eases out of the garage. I know, reverse not forward, but still...
And I swear that mine starts off in first all the time - maybe compensating for only having 340 hp ;-)) when I got it.
Oh - its obvious what the problem is on the car in the video - the steering wheel is on the wrong side!!
Old Apr 3, 2019 | 02:42 PM
  #74
jallitt's Avatar
Mine hasn't done it since I updated to a MY18 SVR
mick99
Jan 14, 2016 07:32 PM
sonicd0012
Nov 20, 2015 11:36 AM
essepi
Nov 20, 2015 09:43 AM
GoodWins62
Nov 17, 2015 12:43 AM
roger.grote
Nov 15, 2015 05:18 PM
