Car not seeming to sense key
Old May 27, 2019 | 12:57 PM
Noshame's Avatar
Default Car not seeming to sense key
I had to replace my garage door opener. I reset the Home link yesterday, no problem. I did not start or drive the car when resting the Home link. I went to Change my oil and air filters this morning and had to use the emergency key to open the door. I get the no key found, and put key here to start message. No low voltage start car message. Car starts with key placed as shown. Drives fine. Outside mirrors do not unfold. I tried the battery reset, but nothing changes. Car won't lock ether. Just get a beep when pushing in the handle. Any ideas? Thanks.
Old May 27, 2019 | 01:12 PM
Nati's Avatar
Might simply be the battery in the fob?
Old May 27, 2019 | 01:26 PM
Noshame's Avatar
I did try both fobs. No joy.
Old May 27, 2019 | 01:54 PM
Dogbreath!'s Avatar
I go with the fob battery as well. If the fobs were within "ear shot" of the car for an extended period they both could be dead.
I've also found that if you have a phone or a key card in the same pocket as the fob, the car refuses to talk to the fob. In that case after I take the fob out of my pocket I open the and close the driver's door to start the the car's listening cycle again. Seems to work.
Old May 27, 2019 | 02:36 PM
Noshame's Avatar
I will replace the battery as suggest. How do you get to the fob battery? I found nothing in the owners manual.
Old May 27, 2019 | 02:45 PM
lizzardo's Avatar
Take out the emergency key and you'll see a hole in the fob that will fit the tip of that key. Insert a few millimeters and twist. The halves of the fob will separate, exposing the CR2032 battery.
Old May 27, 2019 | 03:33 PM
Noshame's Avatar
Thank you.
Old May 27, 2019 | 07:12 PM
Unhingd's Avatar
I had this exact problem a couple years ago. They had to replace the remote module.
Old May 29, 2019 | 09:56 AM
Noshame's Avatar
Update, Well, try the simple things first, Right? The new Key FOB battery seems to have done the trick. Surprised me. I thought no way both key fob batteries are dead at the same time. My DD key is 11 years old with the original battery. So a big thank you to you guys.
Old May 29, 2019 | 10:03 AM
lizzardo's Avatar
I'm not surprised. I keep the battery out of my spare fob because with keyless entry, the fob is always on standby.
Old May 29, 2019 | 04:09 PM
Jagged Wire's Avatar
Please delete. Question was answered in another reply above.
Old May 29, 2019 | 06:58 PM
Unhingd's Avatar
Ummm.. guessing this issue was on something other than a F-Type unless you have a very early prototype.
Old May 29, 2019 | 09:45 PM
Noshame's Avatar
Very early. 😃
Old May 29, 2019 | 09:53 PM
RickyJay52's Avatar
After 4 1/2 years - and one recent fob “failure” - batteries are being replaced...tomorrow!
sgriffith
Oct 4, 2017 03:59 AM
Carl Perkins
Apr 16, 2017 08:33 PM
BigCat1999
17
Jun 29, 2015 01:51 PM
smoggyx100
Jul 24, 2012 01:33 AM
daddyo007
Oct 4, 2011 11:46 PM
