Carbon Ceramic Brakes Shot In 9,000 Miles?!?!
Old Mar 27, 2019 | 08:50 PM
Mahjik's Avatar
The new rotor thing has to do with the transfer layer. Brake pads transfer a layer of material onto the rotors and that's ultimately what the pads grip on. Keep in mind, we are talking microscopic layers here. The theory is that new pads may not bed in properly if there is a layer of material already on the rotor. This is really only an issue if you are altering or switching brake compounds. For example, if you have a harsh compound and switch to a soft compound, it may not be strong enough to remove the old transfer layer and apply it's own. The reverse is never an issue.
Some brake pad manufacturers like Carbotech will tell you whether or not their pad materials can be interchanged without much issue. When staying with the same pad material, the only thing to worry about is the thickness of the rotor.
Good article about transfer layer here:
https://www.apcautotech.com/getmedia...c-8-2018_1.pdf
Old Mar 28, 2019 | 09:00 AM
DJS's Avatar
DJS
That's a really interesting document, thanks.
Old Mar 28, 2019 | 12:57 PM
DPelletier's Avatar
Originally Posted by OzXFR
This has been discussed to death on many forums, but it is standard JLR dealership practice to advise the client "whenever you renew the pads you must also renew the rotors". Obviously not just the CCM brakes but all JLR brakes.
The standard "reason" proffered by the dealership is "for optimal braking performance the pads and rotors must be matched and properly bedded in and that can only be done with new rotors, there is a risk that putting new pads on old rotors will result in sub-standard performance".
I have always called BS on this and I have fitted new pads to used rotors so many times on my Jags I have lost count, and never had a single problem with the brakes.
In general, at least for the OEM steel brakes and pads, one set of rotors will last for two sets of pads before the rotors reach the specified minimum thickness (which is a whopping 2 mm less than new!).
It is different for the CCM brakes, from memory the pads wear 10 times quicker than the rotors and the rotors are essentially "for life".
I agree 1000% - any shop around here replaces (or resurfaces) rotors every time they do a pad replacement for the reasons stated....some even insist on rebuilding the calipers basically taking even an econobox brake job from $200 to $1,000+......yet on my motorcycles (which I service myself) I've been replacing pads only and inspecting rotors for warping, wear or other issues for decades now....even on racebikes that see extreme use. It's all a money grab bunch of BS if you ask me.
Dave
Old Mar 28, 2019 | 01:24 PM
Brutal's Avatar
Without reading all the replies, you dont even need pads @10mm, 8mm. More like 2-3mm.
Old Mar 28, 2019 | 01:32 PM
DJS's Avatar
DJS
Copied this out of the 2014 shop manual. I recall some discussion that CCB rotors should be weighed rather than their thickness measured.
2015.0 F-TYPE (X152), 206-03
FRONT DISC BRAKE - VEHICLES WITH:
CARBON CERAMIC BRAKES
SPECIFICATIONS
WARNING:
Do not mix the specified brake fluid with any other type of brake
fluid.
ITEM SPECIFICATION
Brake fluid Castrol react SRF racing high performance brake fluid
ITEM MATERIAL
Brake disc Carbon ceramic
Brake pad Organic
Brake Lining and Disc Specifications
ITEM SPECIFICATION
Front brake pad nominal thickness 14.25 mm (0.55 in)
Front brake pad material minimum thickness 3 mm (0.118 in)
Front brake disc diameter 398 mm (15.66 in)
New front brake disc nominal thickness 38 mm (1.49 in)
Worn front brake disc minimum thickness 37.5 mm (1.47 in)
Maximum front brake disc runout (installed) 0.10 mm (0.003 in)
Maximum front hub face runout (installed) 0.015 mm (0.0006 in)
Brake disc minimum weight Refer to brake disc
Front brake caliper piston diameter
Upper 38 mm (1.49 in)
Centre 34 mm (1.33 in)
Lower 30 mm (1.18 in)
Torque Specifications
ITEM SPECIFICATION
Front brake caliper to knuckle retaining bolts * 115 Nm (85 lb-ft)
Front brake pad retaining bolt 30 Nm (22 lb-ft)
Front brake caliper bleed screws 14 Nm (10 lb-ft)
* New nuts/bolts must be installed.
Old Apr 3, 2019 | 11:00 AM
dvbydt's Avatar
Hey Bradley, I have the same issue with my car. At 16k miles, I had the 'Ceramic disc brakes worn' cluster message come on. Were you ever able to resolve this issue with your dealership?
Old May 23, 2019 | 08:47 PM
Alex Torres's Avatar
Default Restor CCB
My front CCB rotors are worn out. I heard that some break companies refurbish or restore the disc/rotors. Any advice who can do it? Thanks
Old May 24, 2019 | 01:12 PM
  #28
Ltrain925's Avatar
I briefly read The replies but I can comment on carbon ceramic brakes because I just had them on my c7 z06. Brembo makes them same brand as f type I believe. You can not measure them. They have to be weighed. If you have 9000 miles on your carbon ceramic brakes those things are barely even broken in unless those are 9000 miles of tracking the car. Carbon ceramic brakes have a gas inside that only gets discharged when under extremely high temperatures which is why they tell you to weigh the brakes not measure them. Technically carbon ceramic brakes on the street Should last at least 100,000 miles for the rotors. Pads different story. After five track days of racing my z06 very hard, Rotors were only 80% to weight of needing to be replaced. This goes for all carbon ceramic rotors. They last forever on the street. Whoever told you your rotors are needing to be replaced might be full of crap. I would pull your rotors off and weight them. The scale needs to be in grams and go up to 7-8k grames to be exact. You can’t even look at the rotors and tell to the naked eye they have to be weighed.
Most dealerships don’t know anything about carbon ceramic brakes because they are in fact very different then other brakes. They also require a “burnishing in period” when new that I bet the dealership won’t tell you about.
Old May 24, 2019 | 02:16 PM
Paul_59's Avatar
Banned
Ltrain925 advice seems good to me, definitely rotor wear is determined by weight not thickness.
Any wear warning light would most likely be pad wear
And as said Brembo make the CCB brakes for F type, will definitely be standard fitment on other makes, not Jaguar specific
Old Feb 12, 2022 | 09:00 PM
  #30
gestut's Avatar
Hi
I am looking at f type with CCB, do you specs on the rear for pads etc like you have for the front
thanks
Old Feb 12, 2022 | 09:01 PM
  #31
gestut's Avatar
DefaultHi
thanks
Stwsam
Jan 14, 2018 03:27 PM
Benz2Jaguar
Aug 19, 2015 09:23 PM
SoCalJagS
Mar 7, 2015 01:55 PM
Unhingd
Jan 12, 2015 06:22 PM
