Castrol BOT 750B
Old Nov 11, 2024 | 04:24 PM
TrialByError's Avatar
Default Castrol BOT 750B
With the rarity and the expense of the BOT 750B what oil are you guys using? My research was mixed. Some are using 75w/90 open diff, some 75w/90 limited slip. I’m assuming the differential if open and either is ok.
Old Nov 11, 2024 | 05:51 PM
OzXFR's Avatar
It depends on which model of F-Type you have as they have different diffs and require different diff fluid.
The base model has an open diff for which BOT 750B is OK, the V6 S has a mechanical LSD for which you need BOT 720 (not BOT 750) or equivalent and the V8 (2013/14 V8 S, R and SVR) has an electronic LSD for which you also need BOT 720 or equivalent.
In my V6 S I use Motul Gear 300 LS with no problem and others have used Ravenol also with no problem.
Old Nov 12, 2024 | 06:02 PM
So it sounds like BOT 750B is for open diffs. I’ll source an oil for that. Thanks.
Old Nov 14, 2024 | 08:55 AM
Therock88's Avatar
Some info for you that may help...
TheRock88 Front Differential Oil Change DIY.pdf - Google Drive
TheRock88 Rear Differential Oil Change DIY.pdf - Google Drive
DC
Givoo
Aug 19, 2023 05:51 PM
Shahar Alon
Jan 1, 2019 08:03 AM
brinny
Sep 21, 2018 02:08 PM
Roland M
XJ40 ( XJ81 )
Jul 15, 2015 08:12 AM
hawaiianjag
Nov 6, 2010 10:36 PM
