Centre console buttons stopped working..
Old Apr 19, 2018 | 12:03 PM
leewetherilt's Avatar
Default Centre console buttons stopped working..
Hi all,
I'm hoping someone has a quick solution to the problem that has developed with my 2014 Jaguar F-Type R.
The ECO button, Exhaust note button, Traction and the spoiler raise/lower button have all just stopped working. Normally when pressed, the exhaust button would light up ang get louder, now nothing.
Does anyone have any ideas? Is it a common fault? could it be as simple as a fuse?
Thanks in advance..
Lee.
Old Apr 19, 2018 | 12:12 PM
sov211's Avatar
This is a duplicate posting. First suspect: the battery
Old Apr 19, 2018 | 01:04 PM
DJS's Avatar
DJS
All of those switches go into the 'JaguarDrive Switchpack.' I would guess it could be a fuse for that, or the connection to the CAN Bus.
But, as sov211 says, checking the battery first is always a good idea.
Old Apr 19, 2018 | 02:42 PM
DJS's Avatar
DJS
Check out this document:
https://www.dropbox.com/s/wskjex70o2...ntrol.pdf?dl=0
It describes how the JaguarDrive Control system works. All of the switches you mention feed into the JaguarDrive Switchpack, and the document discusses some of the failure modes. Are you able to check to see if there are any OBD error codes?
I was unable to figure out which fuse powers that switchpack.
Old Apr 20, 2018 | 04:14 AM
Battery is going to be checked and if found to be faulty, replaced.
Many thanks for your help!
Regards,
Lee.
Digital Will
Feb 21, 2026 05:58 PM
V8FTW
Oct 23, 2016 07:45 PM
macboots
Oct 13, 2016 08:26 AM
biffta
Oct 6, 2016 02:37 AM
George Mee
Oct 1, 2016 04:06 AM
