Ceramic Brake Pads
Old Feb 15, 2016 | 11:25 PM
TheStig's Avatar
Default Ceramic brake pads...
Anyone have to replace a set yet? I'm guessing no. The car hasn't been out that long. I am retiring the F-type from track duty (I never intended it to be track toy but it's addicting to throw the car around). After four track days I believe I have diminished the time I have left on these pads significantly. I'm guessing those track days are about to become pricey (as are all track days).
MC
2015 F-type R
1995 Mazda Miata #02
2010 Cadillac Escalade
1996 Acura NSX-T sold
2008 Corvette Z06 sold
Old Feb 23, 2016 | 11:25 PM
LethalElbow's Avatar
I ordered and just received stop-tech posi quiets as well as cross drilled slotted rotors for the front of my 15 f-type coupe R. Hopefully will be getting them installed in the next couple of days. I will post further when I know more....
Old Feb 24, 2016 | 09:17 AM
355rockit's Avatar
Would you be able to share what the Centric Posi Quite part number is for front and rear? Are you just doing Posi-Quiet front or front/rear?
Old Feb 24, 2016 | 09:32 AM
These are the ones I found for the front. I called Stop-tech and this was the number they said I needed. I have not looked into the rears as of yet. Hope that helps.
Amazon.com: Centric Front Brake Pad 104.17500: Automotive Amazon.com: Centric Front Brake Pad 104.17500: Automotive
Just as a side note I bought my 15 pre-owned with only 5200 miles on the clock. A week into owning it I started getting a shudder from the front wheels when braking pretty much self diagnosed as a warped rotor. Then about a week later I was poking around the nav system in the car and found "previous destinations" one of which was Laguna Seca Mazda raceway. LOL probably was the beginning of the end of the factory pads and rotors.
Old Feb 24, 2016 | 03:08 PM
355rockit's Avatar
I looked up the pads on the Centric site. Unfortunately for me these are the metallic and not ceramic pads. Hopefully Centric will release Posi-Quiet Ceramic pads.
Brake Pads Posi-Quiet Metallic w/Shims R, V8 S; Iron Discs; 380mm Front & 376mm Rear Discs Front 104.17500
Brake Pads Posi-Quiet Metallic w/Shims R, V8 S; Iron Discs; 380mm Front & 376mm Rear Disc Rear 104.17530
Old Feb 24, 2016 | 05:26 PM
mshedden's Avatar
If they make ceramics, they should have a '105' prefix on the part number, in place of the 104. Currently they don't make them as far as I can see.
They *do* make ceramics for the BASE F-Type fronts: 105.17510
Old Feb 25, 2016 | 10:36 PM
FtypeRRR's Avatar
no idea, but i'm glad you are tracking it, as i am with mine. such a fun car!
Old Jan 28, 2017 | 03:34 PM
  #28
Atomic's Avatar
Did anyone ever have any success fitting ceramic pads on their F-Type?
Old Jan 29, 2017 | 11:47 AM
Tally Ho's Avatar
Wondering the same. Nothing wrong with my factory pads just getting tired of cleaning brake dust all of the time.
Old Jan 29, 2017 | 12:54 PM
  #30
Stohlen's Avatar
Good braking performance or low dust. You choose.
Old Jan 29, 2017 | 05:53 PM
  #31
Tally Ho's Avatar
I run Hawk performance ceramics on my Corvettes and ran EBC ceramics on the Ferrari F430 I used to own. For a street car the braking performance is just fine. On the track, yes it may be different although I had no degradation coming down from 120-140 after 5 lap intervals at Talladega with my C6 Corvette equipped with the Hawk ceramics. To each their own. I hate cleaning up brake dust every time I drive.
Old Feb 1, 2017 | 06:37 PM
  #32
CaptainDavid's Avatar
Default Also fed up with Brake Dust
Did some research on ceramic replacements and found that "TRW" seems to make them for my 14 F V8S. I recall their website is TRWaftermarket I think.
Hope this helps.
RSpi
Nov 23, 2015 01:12 PM
luds1
Oct 20, 2015 09:53 AM
Stuart S
Oct 12, 2015 07:45 AM
firstchoice
Oct 11, 2015 08:15 PM
texevora
Oct 9, 2015 10:28 AM
