Clunking noise coming from the front passenger side.
Old Nov 27, 2023 | 12:33 PM
Br1445's Avatar
Default Clunking noise coming from the front passenger side.
I have been experiencing a very audible noise coming from the car's front passenger side. The noise seems to originate from the suspension area of the car, and it only manifests when going over bumps or encountering road imperfections. My mechanic has mentioned that he believes my front passenger suspension has "lost pressure" and that I need a new strut. Considering my car has 50,000 miles and is a 2016 model, I find it unlikely for my struts to go bad this early.
Old Nov 27, 2023 | 12:40 PM
clubairth1's Avatar
Community Influencer
Sway bar end links and/or sway bar bushings.
Easy to check. Disconnect the sway bar end links on the front of the car and then drive where it made the noise before.
Old Nov 27, 2023 | 01:13 PM
Br1445's Avatar
Thank you! I will check and let you guys know if that was the issue.
Old Nov 27, 2023 | 01:36 PM
DJS's Avatar
DJS
Also check for loose nuts on the cross braces at the top of the engine compartment.
burnibus84
Feb 16, 2024 10:17 PM
hbeale54
Jul 19, 2022 04:22 PM
Balboa
Oct 13, 2020 10:03 AM
omgimali
Apr 26, 2017 12:43 AM
Delta088
Jun 3, 2016 09:09 PM
