Clutch finally bit the dust
Old Oct 28, 2019 | 05:24 PM
Buckingham's Avatar
Default Clutch finally bit the dust
2016 MT with 13K miles and 1 year of warranty left. It won’t shift into gear with engine running. I had to turn of engine, put it in 2nd and drive to the dealer(about 5 miles) all in 2nd gear. Then I had to show them how to put it in reverse in order to get it in a parking slot. They can’t check it til Wednesday. I don’t know how long to get the parts. Planning to drive to Mendocino on the 7th( if it hasn’t burned down) so I hope it is done by then. I’m probably the last one to get my clutch done of the MY16s.
Old Oct 28, 2019 | 06:44 PM
Unhingd's Avatar
Those parts are in such high demand that it shouldn’t take much time at all to get those parts in. Remind them that they need to order the bolts as well.
Old Oct 29, 2019 | 09:14 AM
rbsj's Avatar
Sorry about that, but at least you were able to get it to the dealership relatively easily rather than being out of town 800 miles away from home like some others have reported. Do give us a report on how the new clutch feels and works for you over time. I'm interested in hearing how the 4th generation clutch is treating people. It's inevitable that I will be in the same spot sometime in the future, but for now my 2016 S has 32K miles and the original clutch is working fine (probably 2nd generation). I would like to know before the time comes, if the 4th generation clutch is solid and worth installing or if other options should be considered.
Old Oct 29, 2019 | 08:03 PM
Buckingham's Avatar
Default Now it works
Got a call from the dealer this afternoon. They could not find a problem. Drove there and test drive with mechanic. It drove fine.
Their driver verified that it would go into reverse when I dropped it off. I took it home and will drive it and see if it happens again. I’m thinking a hydraulic valve sticking and not letting clutch fully seat. We shall see but no new clutch yet.
Old Oct 30, 2019 | 12:30 AM
lizzardo's Avatar
That was symptom #3 for me. Something has come apart and a piece is floating around that will make this recur. I'm not sure if it's from the clutch or the dual-mass flywheel, but I had the same thing happen. When I dropped it off it was showing the symptom, but the next morning when the tech tried, it was working fine.
Good luck.
Old Oct 30, 2019 | 03:01 AM
Unhingd's Avatar
Good luck.
+1. The OP will be back in the shop soon.
mwigent
Jul 14, 2019 09:28 AM
JC#1
E type ( XK-E )
Oct 17, 2017 08:37 AM
AbyJag
Nov 15, 2016 04:23 PM
IronCobra
Dec 3, 2006 07:09 PM
